02-19-2018, 01:06 AM
PlanePower FS1-14B alternator and low voltage light
I am planning to run an FS1-14B as my main alternator in my RV-4 (day VFR only).
When I installed it on my engine I noticed that the lead has the field wire to pin 3, a jumper from pin 3 to pin 2, but unlike any of the belt driven Plane Power alternators I have seen, there is no lead from pin 1 to drive a low voltage light.
Does anyone know if pin 1 will provide this function? I have emailed PlanePower, been redirected to Hartzell, but so far no reply.
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked   ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
02-19-2018, 05:11 AM
Most Plane Power alternators have two wires coming from the unit, a red for field that connects to two pins as you describe, then a white from the third point that offers ground if the alternator fails. Is yours internally regulated?
Jesse Saint
02-19-2018, 05:36 AM
Yes, internally regulated. Pin 1, which is where the low volt signal would come from, is empty ie no white wire.
Chris
Chris Mitchell
Repeat offender;
02-19-2018, 10:16 AM
Yes, it'll drive a fail light - at least my 2014 era model does.
Expect it to be considerably flickery, especially at low RPM. Suggest using an incandescent light or a power resistor in parallel to an LED.
02-19-2018, 11:12 AM
Great, thank you for the info.
Chris
Chris Mitchell
Repeat offender;
02-19-2018, 11:32 AM
Here is link to the parts diagram and schematic from PlanePower/Hartzell. Hope this helps.
https://www.dropbox.com/s/mxjxckbrcf...older.txt?dl=0
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
02-20-2018, 12:34 PM
Keith - thanks - but I can't access anything in the Dropbox....?
Chris
Chris Mitchell
Repeat offender;
02-20-2018, 12:58 PM
Keith Brown
RV-6A sold
Dues paid 9/2020
