  #21
Old 09-29-2016, 01:38 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
This issue has come up before. I would caution that ensuring the correct cells are used and following the steps listed by the original post are beyond the capability of most builders. Even should you be successful, ELTs are routinely disassembled and inspected by an FAA inspector during the ramp check each general aviation aircraft experiences both before and after every flight.
It's just not worth it.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 09-29-2016, 04:29 PM
Ben Meyer Ben Meyer is offline
Does said Inspector have a subpoena? That's the only way they can access your airplane without your permission, correct?
Ben Meyer
FFC
RV-6A
Old 09-29-2016, 06:03 PM
Larco's Avatar
Larco Larco is offline
Maybe I worry to much about certain things but my thought is, IF a passenger is badly hurt or killed in your airplane and the ELT did not work as should have, there may be trouble. But if it didn’t work because it was opened up and repaired in an unauthorized manner you are for sure in trouble. My belief is that it is the owners responsibility to maintain the ELT. The testing should be done and logged by the owner or authorized person per the appropriate FAR. Lots of owners don’t do this because they just don’t know about it.
It’s more of an insurance thing than a FAA matter to me.
I am however impressed with the author of the battery replacement but for 50/75 bucks I would rather have piece of mind.
Just looking at it from a different angle. :-) Larry
Old 02-16-2018, 04:56 PM
SMO's Avatar
SMO SMO is offline
Hmm, maybe ACK got wind of this thread. Here is the new battery I received yesterday:
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 02-16-2018, 05:47 PM
Refer to post #20 in this discussion thread... Posting by ACK. Yup, they came here to set the record straight. I'm glad as I've been preaching this gospel on this forum for quite some time and, sometimes, have felt like I might as well have saved my breath to cool my porridge.
Old 02-16-2018, 06:42 PM
Bevan Bevan is offline
Looking at any perceived liability issue from the other side, what is the ELT's or FAA's liability if the TSO's device (including proper factory batteries) fails to perform during a crash? Are they going to be held responsible? If not, then how can the home-builder who's done his best to keep the batteries current (along with the rest of the aircraft) which presumably has a warning decal for the passenger to see that reads "this aircraft does not conform to internationally recognized standards" etc. be held accountable to any degree higher?
Seems like a double standard to me.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 02-16-2018, 07:31 PM
airguy's Avatar
airguy airguy is offline
Bevan
Exactly correct. If the ELT manufacturer can guarantee me (and my heirs/family), absolutely, that the ELT will perform exactly as intended in ANY and ALL crash scenarios, then perhaps I would be more inclined to pay attention to them protecting their market by emphasizing the TSO requirements.
Old 02-16-2018, 08:14 PM
DanH's Avatar
DanH DanH is offline
Meanwhile back at the ranch....
I recently replaced mine and noticed the expiration time clock seems to start when they manufacture the pack. Soooo, it will probably pay to order yours from a high volume retailer, and then check the date as soon as it arrives.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-16-2018, 10:47 PM
SMO's Avatar
SMO SMO is offline
Mine came from Pacific Coast Avionics and was dated January 26, 2018. I was pleasantly surprised.
Mark Olson
1987 RV-4 Sold
Old 03-11-2018, 05:55 AM
dbuds2's Avatar
dbuds2 dbuds2 is offline
Default TSO?
Do EAB aircraft have to comply with TSO?
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
