  #11
Old 02-15-2018, 05:27 PM
Stoppel Stoppel is offline
Default Lens
I had the same problem. Vans put me in touch with a man in Oregon who owns the molds. I sent him a check for $50 for a lens and never heard from him again. I believe the original manufacturer of the lens was a Yacht builder based in Oregon.
James Stoppel
RV8 Purchased Flying
Old 02-15-2018, 05:38 PM
kentlik's Avatar
kentlik kentlik is offline
Ouch! That hurts...
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 02-15-2018, 06:27 PM
larosta larosta is offline
Default Plastic Blow Molding or Oven Drape Shop
If there are lenses available that could be used to pull the tools from you may want to consider having a shop do a short run.
I used this company several years ago to make some lenses for an application.
Akra Plastic Products, Inc.*
http://www.akraplastics.com/
Look for a shop that does vacuum forming, drape or blow molding of acrylic parts. Give the company a call and spend some time on the phone discussing your requirements. The tooling costs should not be too high. I don't see this one as too big a deal if you find the right shop and do a pool buy in order to amortize the tooling costs.
* This is by no means a recommendation and I do not have nay relationship with this particular company.
-larosta
Old 02-15-2018, 06:50 PM
RVDan RVDan is offline
I am visiting a vendor that does vacuum forming tomorrow. I?ll check to get an idea of the cost to do a short run.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 02-15-2018, 07:43 PM
terry.mortimore terry.mortimore is offline
Default Wing tip lens
Put me down for a pair if you can arrange it.
Terry
Terry Mortimore
RV-6A flying
Based CYAM
Old 02-15-2018, 09:19 PM
Glovebox Glovebox is offline
Were these not made by RMD Lighting for Van's? Here's the website:
http://www.rmdaircraft.com/
Look under 'other products'
Old 02-15-2018, 10:14 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Originally Posted by Glovebox View Post
Were these not made by RMD Lighting for Van's? Here's the website: http://www.rmdaircraft.com/
The RMD Lighting mod kit is much larger than the one above. Big enough for a PAR36 light...
(Picture of Chris C's wingtips)
Paul McVitty
Flyleds.com
VAF advertiser
Old 02-15-2018, 10:51 PM
Stoo Stoo is offline
Anyone tried cutting down the RMD lenses to fit? Shape should be the same.
Stewart Willoughby, 6 panel/wiring
Old 02-16-2018, 01:09 PM
Len Len is offline
Default Lens
I have these on my -8 I finished in 2002. It was a third party not Vans.
Len Leggette
Greensboro, NC
Old 02-16-2018, 11:39 PM
CAVU Mark's Avatar
CAVU Mark CAVU Mark is offline
Default Made some for a TBM avenger
I did a restoration of a TBM for the WWII museum and all we did we make a wood mold for the wingtip lens and sent it off to a local vacuum former. The stretch was a bit much for the plastic but it worked.
Mark
RV-3 restoring
Stearman - N2S-5 completed/flying
L3 building for San Diego Air and Space Museum
Misc. others...
