Originally Posted by Jshepherd
Looking at the new section 10 plans for 12is tailcone assembly, only difference I can see is an inspection hole and cover in the forward end of the tailcone. Hope it?s not important for those of us with tailcone built already
It is important if you're building an iS fuselage. The hole is where the fuel drain goes. My guess is that they will have some sort of retrofit kit to add an inspection hole and cover to Generation 1 tail cone kits that are being used with iS fuselages.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
