  #11
Old 02-09-2018, 07:49 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Originally Posted by jimgreen View Post
A major attraction seems to be the lack of maintenance required. According to the COPA article no inspections or adjustments. Just throw it away after 2000hrs. However, just like any electronic ignition it requires electrons so you need to think about the need for a back up source.
I like the fact that it is self contained and doesn't need an outside timing source - no extra wires vulnerable to damage.
Except in this case the literature specifically says to retain one magneto.
A failure of the unit will simply be the same as losing one magneto, and with much less moving mechanical parts it should have a much better reliability.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Toobuilder's Avatar
Originally Posted by 49clipper View Post
... I fly LOP on virtually every flight. the one drawback which is completely normal is that your CHT's will rise about 30-45 degrees with the advanced leaning...
Advanced leaning or advanced timing? The higher CHT is what is expected from too much advance when ROP, but leaning beyond LOP will drive CHT cooler.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-09-2018, 10:01 AM
777Dave's Avatar
777Dave 777Dave is offline
Thumbs up
This is my thinking too. I would keep one mag. I love simple...
Dave Main
Membership due Oct., 2020
RV-4 0-360-188 Catto 3-blade C-FTDQ...
Old 02-09-2018, 03:36 PM
49clipper 49clipper is offline
Default 49clipper
toolbuilder, yes, timing. (What I was getting at, was if you fire it earlier, the cycle is longer which means more heat in the cylinder for a longer time).
Js
