02-03-2018, 12:26 PM
Autopilot Switch
I put an autopilot switch on my panel to turn it on and off. Would it be best to switch the servos off with the switch, or the Garmin GMC307? Both also have CB I can pull if needed. I think if the 307 is off the servos will not run...... But will it throw G3X alarms? If I switch the servo power and turn that off does the G3X complain then? What's best....
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
02-03-2018, 02:34 PM
I'm having Stein build my panel and had this conversation with him. My AP switch will cut servo power.
RV14A #140083
Flying! 8/12/19
2019 Donation
02-03-2018, 02:40 PM
Plus 1
Same here, switch will cut servo power.
Ed
RV-9A - Down for Panel & Engine Conversion
1946 Piper J-3 Cub - Flying
VAF Donation Paid Feb. 2020
02-03-2018, 04:22 PM
As the autopilot actually resides in the G3X, and I have a switchable CB on the circuit that powers the AP servos, I eliminated an AP switch. My flying practice is to have the AP available at all times (blue button at the least) so I only needed power control for resets or an emergency. Both the servos and GMC 307 are on the main bus.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
02-03-2018, 05:25 PM
In my RV-8A I always used the AP button on the GMC or the red button on the stick to engage/ disengage the autopilot. I also had a toggle switch that could shut off servo power, but it was there mainly as a backup/safeguard and I never needed to use it in flight. I think it's a good idea to have a convenient means of turning off power to individual boxes regardless of their function, whether it be done by CBs or toggle switches (a fuse can also be pulled but is generally more difficult to quickly find and remove the correct one, and harder to restore power again if desired).
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
02-03-2018, 11:54 PM
In larger (certified) aircraft this is called TCS - touch control steering.
Basically the servos (or clutch etc) is disconnected so that you can temporarily maneuver the aircraft while holding the switch, but the ap remains active and trying to steer the aircraft. You let go of the button and the ap will return the aircraft back to where you had it. Good for traffic events or weather avoidance, or any other time you want to temporarily maneuver without taking all the ap modes off and having to reselct them all on again. Usually TCS is a momentary action switch.
Most have a seperate switch which cuts power to everything, in case if servo runaway etc. (ga certified sometimes have this or you just red collar the CB so you can find it in a hurry).
Seems both may be useful in an IFR machine.
02-04-2018, 11:04 AM
In the Garmin G3X autopilot what you are describing as TCS is called CWS (Control Wheel Steering). It is accomplished using the same momentary pushbutton as the AP Disconnect (usually red and located on the control stick). A quick jab will disconnect the autopilot. If you push and hold it instead, it disconnects the servo clutches but the autopilot modes stay active. You can then hand fly the airplane as desired (around a cloud or flock of birds for example). When you release the button the servo clutches re-engage and the autopilot continues flying. In some modes such as Heading or Nav, the autopilot will return to tracking the heading bug or nav reference. In other modes such as Pitch/Roll, VS, and IAS the reference will synch to the current value upon releasing the button. So for example if you were climbing in VS mode at 300 FPM, and you hold down the CWS button and pull the nose up to increase climb rate to 500 FPM and then release, the autopilot will now be using 500 FPM as the new reference to hold. All of this is documented in the G3X Pilot's Guide BTW...
Mark Navratil
Spring Hill, KS
