Old 02-03-2018, 01:07 PM
kentlik's Avatar
kentlik kentlik is offline
Default Decided to start on the canopy...initial fit before cutting anything
Looks like I have a way to go with this puppy...
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 02-05-2018, 11:27 AM
kentlik's Avatar
Default SDS/EFII
Picked this up last year off VAF looking forward to getting to the point I have a need to install it. Going to get one more setup to go full EFI.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-10-2018, 09:29 AM
kentlik's Avatar
Default Brake lines in for test fit of length and chafing
Brake lines in for test fit. No anti-chafe procedures yet addressed or final routing of lines.
Words of wisdom? Also, I need to deal with the sub-panel sooner than later, what do y'all think about just using current rivet holes and scaling in some plates and going from there. I should not have anything going through the sub-panel after the refit of glass panel etc.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-10-2018, 10:58 AM
Ethanol1 Ethanol1 is offline
Can't see the latest pics?
Mike York
President EAA Ch 25
Old 02-10-2018, 11:30 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Work fine here.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-10-2018, 01:06 PM
kentlik's Avatar
I will check on my yoga pad to see if I can see them...
Look good on my satellite computer
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-24-2018, 11:57 AM
kentlik's Avatar
Default pic extension added to chrome
So I added an extension that was indicated by another VAF'er and it seems to work to show all of the pictures once obscured by Photobucket. Promising at least for the short term.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-25-2018, 10:09 AM
kentlik's Avatar
Default firewall doubler
So I had some clean-up and reaming to do on this doubler then priming and will install today after church.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-26-2018, 07:37 PM
jcarne's Avatar
jcarne jcarne is offline
Can't see the last two posts you have involving pictures. I wonder if it's a permission error.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 03-04-2018, 08:24 AM
kentlik's Avatar
Thanks again I have shared it and reshared it and double checked it so I am going to build and use Kodachrome, hahaha
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
