Old 01-31-2018, 06:08 PM
JDA_BTR JDA_BTR is offline
Default Hole below the rudder cable guide in the tunnel?
Where the rudder cables enter the cabin by your feet in the tunnel there is a hole just below that doesn?t seem to have a use. I was considering using it for a wiring Adel in the tunnel but maybe it has a different purpose not yet revealed?
What?s it for?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 01-31-2018, 08:23 PM
Jake14 Jake14 is offline
I used it for an adel clamp...both sides
RV-14A flying 410 hrs
Old 02-01-2018, 06:16 AM
Jesse's Avatar
Jesse Jesse is offline
It should be for an ASEL clamp holding the plastic rudder Cable sleeve in place so the Cable doesn?t rub on the tunnel side.
Jesse Saint
Old 02-01-2018, 08:29 AM
rvbuilder2002's Avatar
The RV-14 uses machined UHMW cable guides mounted in the side panel of the tunnel.
The holes mentioned are intended for clamps to support any systems cables/wires at the mid point of the tunnel.
Scott McDaniels
Hubbard, Oregon
Old 02-01-2018, 10:10 AM
Perfect! I had put nutplates in the unused outboard positions of the fuel pump bracket but putting clamps on the tunnel side will be far superior.
