Old 09-19-2017, 09:54 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by Norcalrv7 View Post
I have been running my SDS injectors in the primer port for the last 75 hours on my parallel valve 360. I can't compare to other positions, but it has worked so far.
Got a picture?
Injectors in the lower cowl space obviously work. It's just interesting to hear the location called "the cool side".
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-19-2017, 11:01 AM
Toobuilder's Avatar
Can anyone confirm the material that the EFIi injector bases are made from? I'm talking specifically about the part that threads into the head. From the pictures, it appears they are anodized aluminum. Also, can anyone confirm the PN of the injectors themselves? The site has a vague reference that they are "full sized".
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-22-2018, 08:01 PM
breister breister is offline
This post is a few months old now - anyone have any hands-on experience with the system?
Old 01-28-2018, 08:31 PM
SinCityJets's Avatar
SinCityJets SinCityJets is offline
Does anyone have a price yet??
Exempt, but gladly paid VAF Dues for '18
Please excuse the dumb questions. I'm an FNG!
Old 01-28-2018, 08:56 PM
Chkaharyer99 Chkaharyer99 is offline
Got a picture?
From: VAF Forums > RV Firewall Forward Section > Fuel Injection Systems > Caleb lesher SDS EFI RV-7A
http://www.vansairforce.com/communit...eply&p=1154922
I used Ross's Throttle body, and didn't want a scoop, so this is what I came up with. I Used a metal piece of aluminum tube in the shape I wanted, then carved a foam block for a transition. It holds a K&N Filter in the left cowling baffling.
20160818_154630 by Caleb Lesher, on Flickr
20160818_162819 by Caleb Lesher, on Flickr
20160819_123750 by Caleb Lesher, on Flickr
20160819_133916 by Caleb Lesher, on Flickr
20160824_194520 by Caleb Lesher, on Flickr
20160824_194524 by Caleb Lesher, on Flickr
Charlie
RV-8
Old 01-28-2018, 10:31 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default ETA Spring
The website says it isn't available until Spring.
I am "patiently" waiting.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 01-29-2018, 09:14 AM
I was quoted a price of $6,195 for the whole system (hardware only, which would upgrade my O-290 to injected / single lever operation as well as dual electronic ignition). Don't know what installation would run, but assume it requires little things like tuning individual injectors. I also confirmed that the entire rig could be re-used on any 4-cylinder Lycoming, although the throttle body might have to be swapped out if diameter or mounting brackets are different. That means you could strip it off and use on another engine, re-mounting mags and carburetors to make the engine "certified" again if you wanted to swap.
Old 01-29-2018, 09:59 AM
Jrskygod Jrskygod is offline
From the pictures above I'm wondering how Caleb is going to deal with alternate air for snow, ice and rain conditions?
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
Old 01-29-2018, 10:19 AM
bret's Avatar
bret bret is offline
Don't fly in the Snow and ICE ? ........sorry
Old 01-29-2018, 10:38 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
For those interested, you might want to pick up the latest KITPLANES magazine and read the "Under New Management" article.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
