Old 01-26-2018, 12:42 PM
jmbaute jmbaute is offline
Default RV accident data analysis
I wanted to learn a new data analysis tool (Power BI) so I decided to build a simple dashboard based on the NTSB database. I thought it might be interesting to the community so I am sharing the link with you.
edit: supposed to be a pic here but for the life of me I can't figure out why it isn't showing.
This is the same data you'll find in lots of other places, including on this website (Doug's page was actually my inspiration).
A couple notes:
- the data source is the XML file on the NTSB site. They update the data once per day. At this time I'm not sure if the link I'm posting refreshes against that data or if I have to trigger that refresh on my side.
- I'm using some custom logic against the entire database of ~81k incidents to get to "Vans" models. This is a little tricky since as you know, you can call your aircraft anything you want at registration. I'm "close" to what Doug reports on his page and for now I'm calling it "good enough".
- The report is fairly interactive, for example click on the model donut to filter the heat map and grid. Same thing on the heat map, click to filter by phase of flight. Click again to clear your filter.
- If you click any of the links to the final report and don't get a result, it is because there isn't one issued yet. I'm just building that URL based on the accident number.
- I'm certainly open to feedback/suggestions but this is just something I'm playing with so I can't promise I'll do anything else with it.
- I don't care if you share the link.
- If a moderator wishes to move or delete this post, I'm fine with that, too.
Blues Skies,
John
John B
Mooney M20C (KPSK)
RV7 Wings
www.pdfplates.com
Old 01-26-2018, 01:22 PM
mturnerb mturnerb is offline
Just visited your page: this is outstanding and should be a great tool for anyone who wants to study RV accidents.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 01-26-2018, 02:53 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Nice work!
I agree.......thanks for doing this...
But this is something I will not be showing my wife!
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-27-2018, 09:23 PM
mbauer mbauer is offline
Thank you for putting this together.
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 01-28-2018, 05:47 AM
StuBob StuBob is offline
That?s really an amazing tool. Thanks for putting in all that work.
Stu F.
RV8
Old 01-29-2018, 06:47 AM
Default All GA accidents
Here is a similar report showing the same data for the GA fleet at large, for the data nerds out there (amateur built not included in this).
Doug, thanks for posting the screenshot on the front page of VAF, if there is value, feel free to add the interactive chart to your accidents page; code snip below, although we are getting slightly different numbers. I'd be happy to discuss what filters I'm using.
Code:
<iframe width="800" height="600" src="https://app.powerbi.com/view?r=eyJrIjoiMTI1OTk1YmItZGQ1ZS00Mzg2LTk4MjMtOWIyNDFjMWVlYWQxIiwidCI6ImU0MmUzNTJmLWZiZDUtNGI3Mi1iOTRlLTFjMDkzNzk0Mjc4MiIsImMiOjN9" frameborder="0" allowFullScreen="true"></iframe>
John B
Mooney M20C (KPSK)
RV7 Wings
www.pdfplates.com
Old 01-29-2018, 07:15 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Does this data take into account flight hours or fleet sizes? If not, what value does this data provide?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-29-2018, 07:59 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Flight Hours
I agree - that was the first thing that popped into my mind - how many hours flown? Unfortunately that's a really hard number to get it seems. It can be estimated, but there are no firm numbers.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-29-2018, 08:39 AM
You're right; there are no denominators, which is what makes the difference between data and anecdotes.
Nonetheless, I think it has tremendous value as a collection of anecdotes. For instance, having read something like 50 reports on ground loops, I've learned that it isn't generally the initial deviation that causes the accident, but the overcorrection. Most of them read like, "Upon landing, the airplane encountered a gust and veered to the left. The pilot corrected with right rudder and brake, causing the airplane to veer to the right. He attempted correction with left rudder and brake but was unable to regain control. The airplane departed the runway to the right....."
I'm not trying to start a conversation about groundloops, just illustrating that these reports are valuable, even if statistically meaningless.
Stu F.
RV8
Old 01-29-2018, 08:48 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I read accident stuff for two reasons - one is to get an idea of the RATE of accidents, and in that case, this data doesn?t;t tell us anything.
But the more important reason for reading accident stuff is figuring out the CAUSE of accidents - and in that case, this is really fascinating information. Knowing what causes accidents can help us avoid them ourselves. Knowing how many (or how often) accidents happen isn?t really useful, except to bean counters.
TRhis is pretty neat stuff - but as I always say, you really need to read the descriptions of accidents to help learn to avoid them yourself.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
