  #31
Old 01-21-2018, 01:27 AM
Piper J3's Avatar
Piper J3 Piper J3 is online now
As a point of reference the following screens are typical for my summer flying - first two OAT 77F and last 55F.
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
Old 01-21-2018, 11:35 AM
rvbuilder2002's Avatar
The carbs are configured so that the mixture is richest at or near WOT.
This is another reason that using an appropriate prop pitch that requires throttling back aways at anything other than rather high cruise altitudes (above 10K) is beneficial for performance.
Scott McDaniels
Hubbard, Oregon
Old 01-21-2018, 11:59 AM
DaleB's Avatar
DaleB DaleB is offline
That's how I'm set up. The only time I see WOT is during takeoff and climb, the rest of the time I have to throttle back some. My static ground RPM is right at 5K, as I recall. Maybe a tad higher. But I'm consistently burning over 6 GPH, and my EGT rarely gets over 1220 or so. Just seems like it's running awfully rich to me.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 01-21-2018, 01:00 PM
Piper J3's Avatar
A few questions...
• Are you really burning 6 GPH as measured by replenishing fuel or are you looking at fuel flow on D-180?
• Is the specific K value for you fuel flow transducer input to the D-180 in setup?
• Spark plugs look like rich burn?
• 912ULS really burns 5+ GPH at high cruise power setting. Don’t believe others reporting lower burn rate.
Fuel Consumption Chart for 912ULS
Jim Stricker
EAA #499867
Old 01-21-2018, 06:10 PM
DaleB's Avatar
Yes, I'm really burning in excess of 6 GPH. Usually 6.5 or more if I'm pushing 5300 RPM. My D180 agrees with the gas pump within 1/2 gallon or so after burning 15 gallons.
Yep.
Nope. Plugs look perfect. Exhaust pipe has black soot.
Ummm... would it be indelicate of me to point out that you say that immediately after posting pictures from your own plane, showing 24.9 MAP / 5160 RPM and 4.9 GPH? <insert smiley here, mate...>
My fuel burn does seem bang on with the chart though. Where did you find that?
Dale
Omaha, NE
Old 01-21-2018, 07:26 PM
I can usually get my fuel burn down to 4.5 GPH AT 5100 RPM and about 21?MAP, but I agree that in high cruise (>5300 RPM) 5.2 GPH is probably more accurate.
Old 01-24-2018, 03:30 PM
Boat Boat is offline
I installed the Van's "Winterization Kit". Oil cooler part is easy to deal with, but the radiator part is so tight that even with "Silicon Spray" all over it, it will not move up and down unless you take the cowl off. Guess I got it set to a good position the first time as the numbers are right and I haven't had to move it.
That Thermostasis is sounding real good about now.
Old 01-25-2018, 09:11 AM
JBPILOT JBPILOT is offline
Default Oil Therm Testing
https://youtu.be/BF_uqyqRJRg
My 205 Thermostassis element was getting tired I think. I installed a new one. Sorry about the video. Hard to fly and hold a phone etc. It is again working like it was when new. The temps on the ground were about 24F degrees ( -3C ). As you watch on climb out, you can see the oil temps increase to well over 200, then the therm closes and forces oil from the cooler to mix with oil from the therm. You can see the temp drop quickly, then stabilize. The tank oil is still warm, but the blended oil going from the Therm to the engine is lower. Hope this helps understand. The temp on the display is not the tank oil, but the blended oil going to the engine.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
