Old 01-16-2018, 05:44 PM
majuro15's Avatar
majuro15 majuro15 is offline
Default Wobbly drill
Need some advice, I have a Pan American 4000 rpm drill that has developed a wobble. I?ve never dropped it nor had any issues. I just noticed oblong holes a few weeks ago. Could this be jus the chuck or should I replace the drill? It?s about five years old and always oiled adequately. Thanks.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
Old 01-16-2018, 06:56 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Have you experienced this with a variety of bits?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-16-2018, 07:07 PM
majuro15's Avatar
Yes both with and without drill stops.
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
Old 01-16-2018, 11:33 PM
RV Jerry RV Jerry is offline
Check for metal chip stuck in chuck
Jerry Scott
Rocket II
Old 01-17-2018, 07:00 AM
Electrogunner Electrogunner is offline
Default Wobbly
Tim,
Don't discount the obvious answer....have you been drinking?
I'm getting close to using that beauty of a prop I got from you..
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 01-17-2018, 07:33 AM
maniago's Avatar
maniago maniago is offline
(I know you been building a long time, and have plenty of experience, so these are just things to consider, maybe spark an idea for you)
If you cant wobble the chuck in any direction by hand, its not bearings. Therefore its your drills or for some reason your chuck teeth, something on them etc. You can get new chucks if you deem it necessary vs buying a whole new handdrill.
If you still think chuck wobble, put it in a vice, make a small wire pointer and check its run out.
Way more likely you have a crappy batch of drills with the bit center ground off center, or the tip was over heated when ground and warped it. Happens all the time with smaller drills.
In anycase (for the noobs out there reading), you should be drilling up to the final size (some people ream, but I'm not a believer in that for small holes up to #30) I go thru tons of 1/8' drills as my starter hole makers. A #40 with a center point off center wont make an off center hole if its being used as an up-size hole maker, at least not that you can tell. You will see it if its a starter hole maker tho.
As a final, I have a dewalt cordless that has developed an off centered chuck to it after many years of use (the chuck jaws are off, not the bearings). I use it when I need to, mostly for big drill stuff, and never for starter holes where hole alignment is an absolute issue.
Also note (and I'm sure you know) that rivets have a squeeze range, not an absolute, so the hole doesnt have to be exact size or roundness (some common sense about limits is obviously needed here).
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 01-18-2018, 06:37 AM
219PB 219PB is offline
If you determine that your drill if faulty, Pan American will rebuild it for free. They did for me last year. Very quick turn around.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
