Old 01-14-2018, 08:53 PM
2johns 2johns is offline
Default carb icing in Rotax 912 ULS in an RV12
Has anyone had carb icing in their RV12
Old 01-15-2018, 02:34 PM
gblwy's Avatar
gblwy gblwy is offline
Not I (in soggy Scotland)
Old 01-16-2018, 06:09 AM
Infidel's Avatar
Infidel Infidel is offline
I've accrued a couple hundred hours behind 912/912S' and have never encountered icing.
Old 01-16-2018, 06:45 AM
Super Moderator
Over 1300 hours behind 912's in Kitfoxes, RV-12's, and Just Superstols with no carb ice. That includes flight in actual IMC as well.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 01-16-2018, 10:36 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
In another thread titled "Air Induction Option" I wrote that the J3-Cub I owned for more than twenty years had an updraft carb on Continental A65-8 engine. You could view the entire carb through the open cowling. I would land on a hot summer day and the carb would be dripping wet (literally) from condensation - cold carb / humid air. Carb ice was always a possibility.
I have 300TT on my RV-12 with zero incidence of carb icing. Nice powerful, smooth running engine...
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
Old 12-04-2019, 08:25 AM
Art_N412SB's Avatar
Art_N412SB Art_N412SB is offline
Default How hot is it?
So, the air around the carb filters is hot because it is at the back of the engine. I get that. But, how hot is it? Did Van's put a temp probe near the carb filters during flight testing? I think about these kind of things on wet Pacific Northwest days.
Art Tiller
Pacific Northwest
RV-12 Owner
UH1H VN 1972
Old 12-04-2019, 08:58 AM
rvbuilder2002's Avatar
A lot of testing (including the use of temp sensors) was done during the early development of the RV-12.
This was more for evaluating what benefit in performance there would be if a cold air induction system were used (yes, even that was tested but found to not be worth the added cost and complexity).
This testing (and Van's is locate in the wet Pacific North West), along with the accumulated flight time of 650+ RV-12's flying many thousands of hrs around the world, in widely varied flight conditions, has provided data that indicates carb. icing is not an issue.
Scott McDaniels
Hubbard, Oregon
Old 12-04-2019, 12:18 PM
RV12JT RV12JT is offline
During my annual/condition inspection, my mechanic showed me how the Rotax was designed and showed me the fitting adjacent the carbs that hot coolant flows thru. So, no need for carb heat it?s built in.
Old 12-04-2019, 12:47 PM
Originally Posted by RV12JT View Post
During my annual/condition inspection, my mechanic showed me how the Rotax was designed and showed me the fitting adjacent the carbs that hot coolant flows thru. So, no need for carb heat it’s built in.
The standard 912ULS engine delivered by Van's with the RV-12 kit does not have any passages that route hot coolant through/around the carburetors (and I am not aware of any other version of the engine that does either).
There is an aftermarket kit to add this but I am not aware of any RV-12 ever having it installed, though I guess it is possible that yours has.
Scott McDaniels
Hubbard, Oregon
Old 12-04-2019, 01:07 PM
Tony_T's Avatar
Tony_T Tony_T is offline
I believe RV12JT has a Sling aircraft. Sometimes important details are left out.
Tony
E-LSA RV-12 ULS
