Originally Posted by longline
I am about to build the ignition harness for my dual Pmag equipped parallel valve O-360. I know that the NGK plugs that are recommended, BR8-ES, are resistor plugs.
What type of wire is used? I would think that we should avoid the wire core wires, because of RFI.
I see 7MM and 8MM wires available. Which is recommended?
I have two sets of pre-terminated 4 cylinder wires that have only been used for the test stand runs of my engine. They are the E-Mag OEM wires that come with the P-Mags. If you buy them from E-Mag they are $75 each, I will sell you mine for $40 each including shipping.
I changed my wires out because we wanted blue wires to coordinate with the engine and airplane paint colors. Yes, I know my OCPD is showing
