  #11
Old 01-09-2018, 09:36 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default SafeAir1
Are the SafeAir1 tanks still available? I can't find a working website for SafeAir1.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 01-09-2018, 10:01 PM
160kt 160kt is offline
Default Aux Tanks
Try http://hotelwhiskeyaviation.com/
These may be the same?
Old 01-10-2018, 05:59 AM
Mel's Avatar
Mel Mel is offline
Yes, these are the tanks that SafeAir1 was handling.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-10-2018, 12:46 PM
longranger's Avatar
Tuckey tanks
RV-7 TU 904KM (reserved)
Construction Log
Old 08-08-2019, 10:43 AM
timotb timotb is offline
Default 1 hour aux tank on right seat
I'm reading all kinds of ideas for permanent aux fuel tanks. In the tips, drop tanks that don't drop, Hotel Whiskey.....
I don't see where anyone removed the right seat, securely mounted a 10-12 gallon bottom feed tank inside the cockpit, connected it to the vans supplied fuel selector and vented it to the exterior. Im considering this and would like to hear comments on this wisdom or lack thereof. An extra hour is all I need. Simple install and removable later.
I want to fly this 21 gallon per side RV7A from NE Ohio to Tampa with one fuel stop and do it COMFORTABLY. I flight plan 10 gallons per hour but believe the burn is less with my YIO-360-M1B. Probably can do it now but both arrivals will not leave any margin for error.
Tim
Old 08-08-2019, 12:07 PM
Reformed SeaSnake Reformed SeaSnake is offline
Default Bladder type ferry tank
Tim,
You might look into a bladder-style ferry tank. Turtlepac makes some specifically for small aircraft and there are probably other manufacturers. The smallest one I saw on a recent look at their site was 25 gal but they used to make them as small as ~10 gal. The price is higher than the rigid tank you describe, but the bladder does not need a vent and is designed to be held in place by existing harness.
Jason Rood
Beaverton Oregon | RV-8A, Very slow QB
No Pithy quote here; just the sincere hope that your day ends better then it began
Old 08-08-2019, 12:20 PM
airguy's Avatar
airguy airguy is online now
Tim
Here you go - 7.5 gallon tanks that can fit behind either seat in the 7/9 and extend about 3" into the baggage compartment. There's 2 hours of range for you without removing the passenger seat.
https://www.smoke-system-helper.com/tanks-only
Old 08-08-2019, 01:10 PM
This is a good start and might work....was hoping to do a minimum of 10 gallons and not add to aft CG
Old 08-08-2019, 01:19 PM
airguy's Avatar
Put one behind each seat, that's 15 gallons. I have a pair of them myself, the construction is excellent.
Old 08-08-2019, 02:27 PM
Bicyclops Bicyclops is offline
I put one of those behind the copilot seat. It's worth 7.3 gallons, full to the neck. I tell my totalizer that it is 7 gallons. I have a fuel pump with built in check valve under the floorboard of the baggage which pumps into the left main. I start pumping once I've used 3 or more gallons on the left. Since bladder range is usually my limiting factor, I mostly use it for loading up where the gas is cheap and fill the mains only where it's not such a bargain.
With any kind of tailwind and LOP, 38 gallons is way plenty fuel. ROP into a headwind, more capacity is more better. I probably wouldn't have bothered to install it if I'd had the 42 gallons that newer models have. I just didn't want to be the guy that made everybody stop early.
Ed Holyoke
RV-6
