Go Back   VAF Forums > Model Specific > RV-6/6A
Old 09-21-2017, 01:51 PM
Tram Tram is offline
Default RV-6 tailwheel "stinger" removal?
Ours is starting to show its age. We didn't build the plane, so I'm unsure how this is installed.
Is it "easily" removable for painting?
Old 09-21-2017, 01:57 PM
JonJay's Avatar
JonJay JonJay is offline
Yes/no/maybe.
They are installed with only one vertical bolt, but are usually a very tight fit. Unless you have corrosion, or are concerned there is, I would consider painting it without removal. You can remove the bolt and give it a try, but my experience has been they are tight, tight, tight.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 09-21-2017, 02:13 PM
If you absolutely have to remove it, a 50/50 mix of acetone & ATF is liquid magic dust.
Old 09-21-2017, 04:56 PM
BillL BillL is offline
You should contact Vans and buy the USB drive with your planes drawings and instructions on it. That will give you information on how (mostly) it is assembled and the correct bolts, spacers, washers etc.
Bill
RV-7
Lord Kelvin:
Old 09-22-2017, 11:16 AM
That's an excellent idea.
Had no idea they'd do that.
Old 09-22-2017, 11:17 AM
Sounding like it's easier to just repaint while it's installed.
Old 01-08-2018, 12:34 PM
Robski Robski is offline
On my plane (which I didn't build) I just disconnected the chains, removed the nut, pulled out the bolt and out slid the spring.
I have to say it was all VERY well greased, and got a good dose of the same when I put it back together!
Much easier to strip and reassemble tailwheel and clean and paint spring on the bench than on the plane.
Getting the tailwheel off the spring on the other hand....
Rob Swain.
If the good Lord had intended man to fly, He would have given him more money.
1994 RV-6: bought 2008 & improving it ever since.
Old 01-08-2018, 02:29 PM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
The spring is the actual "stinger." I was confused by this in the beginning because the wheel is moved with actual springs in line with other hardware (in stock trim anyway).
Haven't had to take mine out but I do have a set of preview plans I bought when I thought I might try to build a plane. Then I decided to buy a plane. They have been very helpful as the other poster mentioned.
Old 01-09-2018, 07:32 AM
Snowflake's Avatar
If you dribble acetone and ATF around and it gets on the outside where the paint is, you may get to paint the tail of the airplane, too!
Rob Prior
