Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #141
Old 11-09-2017, 02:51 PM
MauleDriver's Avatar
MauleDriver MauleDriver is offline
My reading of the yellow spots doesn't suggest that there is necessarily a problem.
As far as the FSDO is concerned, they didn't ask for it, and while I broke the rule of not offering up more than asked, the report was mentioned in our communications.
I have the feeling that it will not be part of my next report.
Old 12-28-2017, 01:49 PM
I still get the yellow spots. No concern on the part of my FSDO. I don't think the yellow NACv result is a problem.
Old 01-03-2018, 07:20 PM
rleffler's Avatar
rleffler rleffler is offline
Default Garmin ADSB + Format 1 and Format 2
Charlie Waffles brought this to my attention.
I upgraded to 6.41 after I worked on the AMOC. At that time, the only choices were ADSB and ADSB+. After upgrading to 6.41, there is now an ADSB+ Format 1 and an ADSb+ Format 2. The question that I was asked was which one of these are the right option for the AMOC. This caught me totally off guard.
I check my GTN 650 tonight. After the 6.41 upgrade what was ADSB+ was changed to ADSB+ Format 1.
A question for g3xexpert is my assumption that Format 1 the same as the original ADSB+? Then what is different with Format 2 and what requires that setting?
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-04-2018, 11:06 AM
rleffler's Avatar
I was just told by a non-Garmin source that Format 2 is something Garmin made for their GDL 82 device.
So if you're looking for ADSB+, select ADSB+ Format 1
Bob Leffler
Old 01-06-2018, 05:55 AM
ecurington ecurington is offline
Default UAT Console 4.1.0
I need the UAT console that supports the Garmin 430W/600B AMOC. My version does not have an input option for the 430w. If someone could email version 4.1.0 I would be thankful.
Eulice Curington
RV-10 N104EW
Still Painting
Old 01-06-2018, 06:18 AM
rleffler's Avatar
Eulice Curington
RV-10 N104EW
Still Painting
Send me an email, do NOT PM me. If you click on my userid, you?ll find a link to email me.
Bob Leffler
Old 01-06-2018, 10:44 AM
Default Email Sent
Thanks Bob
Old 01-06-2018, 12:29 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I can confirm that this indeed works with the ADS-B+ Format 1. Just wired up my unit and this format worked as intended.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 01-19-2018, 07:12 AM
cardmarc cardmarc is offline
Default Navworx issues after AMOC work, GNS 480 port 3 ADSB+ out position info
Originally Posted by recapen View Post
Folks,
I know there are at least a couple of us out here with NavWorx equipment with non-AD related technical issues...while waiting for NavWorx to respond to our technical issue help requests, we should attempt to help each other.
To that end, I have a 6A with a NavWorx ADS600B -13 connected to a 430W, SL-70, and MX-20...
My unit displays "Ready for Flight" and "TX/RX Error", while not actually working. The "TX/RX Error" only showed up after I was able to get the transmitter turned on...which required installation of an older version of software as the "Activate Transmitter" feature had been removed from later software versions - then upgrading to the latest required software.
All of the other attached equipment in my environment appears to be working properly and communicating with the ADS600B -13 unit.
I can offer my environment to help test other folks units that are having technical issues. I would also request that others make available their working environment to test our non-working equipment in as well as known-good equipment for testing in our environment. Since we have some time before the 2020 mandate and don't know the NavWorx ongoing support status - this is most likely our best solution...aside from abandoning the NavWorx hardware and repurchasing an alternate solution.
Thanks for your collective consideration,
Here's my issue:
Used AMOC to connect compliant position source to Navworx box and disconnected the internal Navworx gps via rs232
Equipment interconnected:
Navworx 600B-13 (AD unit) with 429 option, wifi adapter
Aspen PFD & MFD (mfd did get traffic prior to this change)
GMX 200 using 422 lines from Navworx box (port 1?)
SL 70 set up as 'remote' to supply rs232 baro alt and squawk code to Navworx box
Issues:
1. never got Navworx wifi to send traffic via wifi on port 2 to my Wing x pro, but FIS worked (will we ever get a fix for that? UAT 5.0?)
2. After connecting the GNS 480 port 3 ADSB+ out, I had to select the 430/530 drop down to get the 3 green 'ready for flight' boxes on the 4.1 UAT console outside test
3. (This is bad) I cannot now get the GMX200 port 4 422 to show the Navworx test traffic/FIS or my N #. DATA SEEMS INTERMITTENT, when looking at data tab on mx200 data tab
Any ideas on WHAT is going on?
MW
Old 01-19-2018, 07:13 AM
Folks,
Add me to you list. More later.
Here's my issue:
Issues:
MW
