Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 01-02-2018, 06:09 PM
azflyer21 azflyer21 is offline
Default Dynon Quick Panel
I haven't been able to find any recent post on the Dynon Quick Panel. If you have used their quick panel service I would like to know:
-What is your overall experience?
-Did the Advanced Control Module really help with the install?
-Any issues or gotcha's with the Advanced Control Module?
Thanks for any info.
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
Build Log
Zenith 750 completed 2016 -
Sold
Old 01-02-2018, 07:15 PM
N402RH's Avatar
N402RH N402RH is offline
All of these companies have extensive recent experience with installing Quick Panels and Panels without using the ACM Module.
Bend Aircraft Builder's Assist and Maintenance Center
Mike Robertson
EMAIL: mrobert569@hotmail.com
Synergy Air
www.synergyair.com/
Aerosport Products
www.aerosportproducts.com
Geoff Combs (Currently Upgrading RV-10 from Circuit breakers to ACM)
You can also give us a call for references.
Rob Hickman
Advanced Flight Systems Inc.
Old 01-02-2018, 08:24 PM
Jpm757 Jpm757 is offline
I chose the AFS quick panel for my RV7 using dual 5600 touch displays, with Dynon A/P servos, and dual ADAHARS. No doubt saved hundreds of hours of labor using the ACM and associated pre-wired switches and harnesses. The panel fit perfectly with no trimming required. The installation is surprisingly simple but still requires "customizing" some of the harnesses to accept the specific equipment you are installing such as trims, lighting, fuel gauges etc:. All in all I couldn't be happier with the end result. Fantastic equipment and features, as well as terrific customer support.
If you considering going this route, I would be more than happy to talk with you or give you a demo flight.
Based KOXC (Waterbury-Oxford, CT).
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 01-03-2018, 05:01 AM
Pat Stewart Pat Stewart is offline
Outstanding product, highly recommend.
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 01-03-2018, 05:27 AM
rleffler's Avatar
rleffler rleffler is offline
I have several friends that have installed the quick panels with the ACM in their aircraft. They have all had AFS screens, but I don't think that matters. Rob's team does a great job with both construction of the panels and harnesses, as well as ongoing support. It really doesn't matter if you get either a Skyview, HDX, of AFS screens. The results are equally outstanding.
This is a great option if you are a little intimidated with all the wiring and system design, or if you just want to save some time in the build.
I don't know the timing of the release, but AFS has a prototype of an ACM unit with electronic breakers. When it's gets released, I think it will give some competition to Astronics VP/X. When there is competition, I think we'll start seeing more innovation from both companies.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-03-2018, 04:54 PM
I helped install the Skyview HDX dual screen quick panel with all the bells and whistles in a friends steam gauge RV7A. The product was outstanding with great manuals and customer support. Just like the quick build vs slow build this option is much faster and the actual cost per hour for the plug and play panel is very low.
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 01-03-2018, 07:38 PM
N402RH's Avatar
We have updated manuals on the web site:
Quick Panel Manual with the new ACM-ECB
http://dynonavionics.com/downloads/a...ual%20V4.4.pdf
AF-5000 Pilot Guide
http://dynonavionics.com/includes/gu...al%20V15.0.pdf
HDX Pilot Guide
http://dynonavionics.com/public_html...ev_B_v15_2.pdf
I came up with the idea for the Advanced Control module with plug-and-play wiring after years of helping customers install and trouble shoot avionics in airplanes. After 17 years of trouble shooting problems in home wired and professionally wired panels and seeing how long it took the average customer to install them there had to be a better way.
With the Advanced Control Module (ACM) all of the avionics are on plugs, easy to install and easy to fix. Decide you want to upgrade your GNS430 to a GTN650? With the ACM based panel unplug the old tray and literally plug in the new GTN650 tray and harness. What would probably take you at least 8 hours with a traditionally wired panel can be done in 30 minutes. Decide you want to upgrade to IFR from VFR? No problem plug in our Avidyne IFD540 harness and mount the new tray and you're done. No installing ARINC modules and trying to figure out all the audio, RS-232 and ARINC wiring.
Have an avionics problem? No problem. You can remove the component and its wiring by unplugging a harness. You can then work on it on the bench instead of on your head under the panel or we can send you a new harness.
We currently have a customer that decided to install an EFIS, Transponder, ADSB, Autopilot, Audio Panel and IFD540 in a flying plane. He decided that his local avionics shop could install it without using our ACM. They still are not finished and they have over 300 hours in it. The labor to install it will end up being more than the components!
I have rewired my RV-10 panel three times in the last 9 years. My first panel used traditional switches and Circuit Breakers. On my second panel I replaced the Circuit Breakers with a VPX-Pro. It saved a huge amount of wire and I was extremely happy with how it simplified the power wiring.
When Aerosport Products developed the 310 carbon fiber RV-10 panel and we had the AF-5700 12" EFIS for the center screen I had to have it. Even though we were selling the ACM module I had no intention of removing the VPX and rewiring my panel again
With my new panel I also decided to replace my SL30 with an IFD540. This was 14 days before Oshkosh, plenty of time. After spending about 8 hours under the panel tracing and pulling wires I had had enough, there had to be a better way. I drove to work and grabbed an ACM and a bunch of pre-made harness and starting installing. In a few hours of work I literally had the 3 EFIS screens, transponder, ADSB, GTN650 and IFD540 up and running. Over the next few days I wired all the switches, lights, Alternator and fuel pump to the new ACM. The wiring had never been cleaner and it is now a lot easier to work on.
With my new panel I did miss the ability to see the load on each circuit and the ability to shut off each component individually. With the automotive fuses it was extremely simple and reliable. Five months ago we had our first prototype ACM-ECB with Electronic Circuit breakers and I decided it was time for another RV-10 upgrade. It look about an hour to replace the Fused ACM with the new Electronic Circuit breaker version. It uses the same mounting and wiring! I have now been flying for the last four months with the new module and it is working extremely well.
Rob Hickman
N402RH RV-10
Old 01-04-2018, 04:10 AM
timfwalsh01@comcast.net timfwalsh01@comcast.net is offline
Default ACM
Rob,
This sounds to be an awesome product.
Do you sell the ACM separately? Tim
Tim Walsh
Velocity 173 FG N129VA
Manassas, VA (HEF)
Old 01-04-2018, 11:16 AM
N402RH's Avatar
Originally Posted by timfwalsh01@comcast.net View Post
Rob,
We will sell the module in a package with all the harnesses, we call it a panel-less panel.
Rob Hickman
Old 01-05-2018, 05:09 AM
Default ACM
Rob,
This is great, I will send you a separate email. Thanks Tim
Tim Walsh
Manassas, VA (HEF)
