Old 12-24-2017, 04:09 PM
Steve Melton's Avatar
Default 3 deg downwards trim and buttons
proto4 installed.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 12-24-2017, 04:35 PM
Default model
no wasted space
Steve Melton
Cincinnati, OH
Old 12-25-2017, 11:21 AM
db1yg's Avatar
db1yg db1yg is offline
Default Fairings
Hey Steve,
Looking good -- can't wait to see your test results!!
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 12-25-2017, 11:35 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Looking good, Steve! I hope those aileron hinges are next. Thanks for sharing the R&D process with us.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 12-27-2017, 01:19 PM
Default looking forward to proto4 install
I am getting close to buttoning up this project.
close up view as printed no surface clean up. increased the print resolution on the button faces. for flat surfaces, I prefer a file to sandpaper for clean-up. I think ABS plastic would make good whittling material.
Steve Melton
Cincinnati, OH
Old 12-28-2017, 10:16 AM
Snowflake's Avatar
Have you tried an acetone vapour bath? That would clean those ABS parts up quite nicely regardless of filing/sanding/etc. marks.
Rob Prior
Old 12-28-2017, 10:54 AM
I tried it once but didn't much care for the smell. I perfer to file the nibs and use a little sandpaper. The airflow surfaces are smooth enough and the basic shape is what smooths the flow.
Steve Melton
Cincinnati, OH
Old 12-29-2017, 09:01 PM
Default large spool base
getting some wiggle from the large spool side mount, 11 lb spool. decided to base mount large spool. a quick job. make a quarter of the part then mirror to make a half then mirror again to make full.
printed part weight = 1.1 lb. material cost = $12.36
deflection analysis
4X the vertical loading, 44 lb
1 lb side loading
boundary condition
X displacement, deflection outboard = .14 inch with 1 lb load forcing top open
stress, negligible
Steve Melton
Cincinnati, OH
Old 12-29-2017, 09:10 PM
Default button are handed
decided to go for green buttons for the right hand side so not to be confused for the left hand side, small parts.
ready for flight test, maybe get an extra knot with everything buttoned up? appreciate the push to get the buttons in there. it cleans it up.
Steve Melton
Cincinnati, OH
Old 12-30-2017, 11:47 AM
JKintzle JKintzle is offline
Steve,
Beautiful work and green buttons for the right side are a nice touch (red on the left side?).
Question I had is how you're permanently attaching the gray plastic rear piece to the flap hinge? I see it is currently attached with what looks like painters tape.
Great job!
Jeff Kintzle
RV-9A. N43KK
