Old 12-20-2017, 05:25 PM
togaflyer togaflyer is offline
Default What is a 10 filed as
What do we use as a designation for the Van's -10 for filing a flight plan
Old 12-20-2017, 05:49 PM
Flandy10 Flandy10 is offline
RV10
No dashes.
Scott Flandermeyer
Rv-10 TDI 300 hrs
Fayettevile, GA
2020 VAF Donation complete
Old 12-20-2017, 07:26 PM
Jesse's Avatar
Jesse Jesse is offline
What Scott said.
Jesse Saint
Old 12-20-2017, 09:11 PM
Robertc's Avatar
Robertc Robertc is offline
Try this. Pg C133 or 545 of the document.
https://www.faa.gov/documentLibrary/...esignators.pdf
Bob
Old 12-20-2017, 09:50 PM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default HBX?
Great resource Bob. Isn't there also a generic "experimental" designation. I seem to recall one for TAS less than 250 knots and one for greater than. The designation "HBX" sticks in my mind.
For the record, I prefer it when pilots use the "RV#" designation. That makes it more fun when flight following.
Bob
Michael
Danville, IN
RV-7A Canopy/Finishing
N317PU Reserved
2020 Dues paid (February 2020)
Old 12-20-2017, 10:00 PM
PilotjohnS PilotjohnS is online now
Default Huh
RV4T ? Is that RV 4 turbine? Does one evn exist?
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
Old 12-21-2017, 12:28 AM
mikerkba mikerkba is offline
Default Flightaware has something you might like
From the main page at flightaware.com, you can pull down the "live flight tracking" menu and pick "browse by aircraft type." There, in order of the number of each aircraft type, is a count of aircraft currently "in the system" covering most of the globe. Some countries dont participate and many VFRs not "in." Scroll down to see more GA aircraft types. Always a few RVs, seems like mostly 7 and 10s. (You can ctrl-F search for "RV" and get all models.)
Amazes me that, at most any time I look, there are as many as 2000 737s (maybe 2000 if you count all 737 models) and close to 2000 Airbus A320s airborne.
For any type on the listing, click the type and get a map of where there are. From there, you can click a particular flight to get specific flight data (speed, altitude, route, etc.) More ADS-B, more data, less privacy.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworked: N4032Q RV8A (8/2017)
Building: S-21 Outback/Titan, tail and cockpit mated (3/2020)
KELY/Ely, NV
Old 12-21-2017, 05:33 AM
I see what I did. While setting up my account in fly Garmin I typed RV-10. It accepted RV10. When you contact the tower, do you use the term Experimental with your tail number or specify RV10 with your tail number. The CFI who checked me off would contact the tower with " Experimental (with tail number). And thanks.......
Old 12-21-2017, 05:39 AM
Auburntsts's Avatar
For Tower/ground on initial contact I use Experimental RV 728TT. On Subsequent calls I omit the Experimental. For calls to app/dep/center I just use RV 728TT.
Here's the wording out of my OPLIMS: "The pilot in command of this aircraft must notify air traffic control of the experimental nature of this aircraft when operating into or out of airports with an operational control tower. When fling Instrument Flight Rules (IFR), the experimental nature of is aircraft must be listed in the remarks section of the flight plan."
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 12-21-2017, 06:25 AM
MarkW's Avatar
MarkW MarkW is offline
I use to use Experimental 14MW for initial calls. Now I us RV14MW on all calls.
Had approach reply back to me once as Army14MW. I guess they sound close to the same. I quickly corrected them. I guess my speed made me look just like a F16.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
