  #11
Old 11-28-2017, 08:47 PM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
Default Antenna?
I had a similar problem (I think) a while back. What fixed my problem was the connection from the lower comm antenna to the antenna itself was frade and once I replaced that connection with a new connector the problem went away.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 12-14-2017, 11:30 AM
Stan Bahrns Stan Bahrns is offline
Default I found the problem
Evidently when I last installed the radio I didn't didn't get the lug on the screw that draws the radio into its mount in the right slot & even though it was tight it didn't draw the radio in far enough.So it evidently made good contact with the pins ok for about 125 hrs & then started losing connection intermittently & finally not at all. Was an easy fix once I figured it out. Probably would have saved a lot of work if I would have just pushed in on the radio in by hand.
Stan Bahrns
RV-7A QB
N868B 365 hrs
RV12 40 hrs
Effingham,(southern) ILL
