Old 12-10-2017, 07:09 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default FI tuning
I converted my O-320-C2B to FI using a Bendix RSA-5 Servo and mechanical injectors. I suspect the RSA-5 came off an IO-360 as it's slobbery rich at full and requires most of the travel to lean and goes quickly from "lean" to off.
I'm doing an overhaul and I'd like to clean it as well. While I'm doing that, does anyone know the procedure for tuning an RSA-5?
-Bruce
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 12-10-2017, 07:55 AM
rleffler's Avatar
rleffler rleffler is offline
-Bruce
Give Don Rivera at Airflow Performance a call. The procedure may be on their web site. I believe the procedure is the same for both RSA and AFP. Don can also supply you the injector restrictors at a good price.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-10-2017, 10:55 AM
BruceMe's Avatar
Thumbs up
That's what I needed!
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 12-11-2017, 08:37 AM
Rupester Rupester is offline
Also, know that there is an idle mixture adjustment on the throttle side of the servo ... Generally adjusted to achieve a 40 RPM rise at idle-lean setting. That made a huge difference on mine for ground/taxi ops. And yes, Don Rivera at Airflow Performance is The Man when you get to GAMI checks and nozzle tuning.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
