Old 10-02-2016, 12:02 PM
Stockmanreef Stockmanreef is offline
Default Dimpling firewall flange question
This is probably a dumb question, butt....
After match drilling the hinge and the shim on 29-08, I assume that the firewall flange needs to be dimpled?
Where in the plans does it call that out? I have looked but can't find it
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 10-02-2016, 01:27 PM
Nova RV Nova RV is offline
It doesn't - I asked Vans this exact question several weeks ago because it states earlier specifically NOT to dimple the side flanges. However, I was told that after you do the match drilling it's time to dimple the side flanges so you can rivet the flanges and shims and hinges together. Hopefully they will revise this section.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 10-02-2016, 02:27 PM
very weird that this would be missed with the last revision this year. I am sure that they must have had this call numerous times. Time to uncle the side skin and dimple.
Which is what I thought I would have to do.
At least I have not clecoed on both sides.
ken
Ken Stockman
Midland, MI
N73XP
Old 04-01-2017, 06:54 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Just ran into this issue myself. Time for a new revision Vans.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 04-01-2017, 09:43 PM
JDA_BTR JDA_BTR is offline
I hit that spot, scratched my head, and figured it just had to be done.... The plans are so exacting I worried that I was going to regret it, but so far so good. There are a couple rivets for the baggage area in the same vein can't remember exactly but I asked here a while back.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 12-04-2017, 12:50 PM
Imlars Imlars is offline
Thumbs up firewall flange dimple
Thanks guys for posting this. Arrived at this section of plan and did the head scratch too. (First I thought I screwed up though)!
Old 12-04-2017, 02:32 PM
mturnerb mturnerb is offline
Don't recall where/if in plans the firewall flanges get dimpled, but it's important not to do it until after match drilling the cowling hinges and shims.... (And after that I don't think it really matters when you dimple them, just don't do it BEFORE the match drilling)
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
