Old 11-04-2017, 07:43 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Truth be told, almost every one of the planes being built is for self-indulgence. It's great that you take the time to share your experience with everyone else.
I can see several advantages to the bonding process. Wondering if you've considered some of the newer adhesives developed for the automotive industry. Most of the auto manufacturers are using adhesives in areas formerly welded; they're that good. It's allowed them to combine steel and aluminum in areas that would have been impossible to do before. Even the repair shops are replacing welds with glue.
Bought an ebook on fermentation a couple weeks back. Sourdough was one of the things that I've decided to try. Did it many years ago but failed to use it enough to keep it alive. Didn't have the discipline to devote to it.
Thanks again for your posts.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 11-04-2017, 12:50 PM
I'm trying not to reinvent things here. I'm using one of the two epoxies that are recommended by my mentor, who has tested it. The other is 3M's 2216. Another friend, in the marine industry, has also recommended G/flex for aluminum bonding.
While there are many glues, I don't know what the automotive industry uses or even what the glue companies recommend.
Dave
Old 11-06-2017, 07:15 AM
wilddog wilddog is offline
David,
Question, if you should ever have to replace a glued and riveted skin, how hard would it be to remove with the glue holding it?
Old 11-06-2017, 10:55 AM
Good question!
Probably quite difficult. Heat might help, I don't know. Or my glue prep might prove insufficient and the pieces might pop apart. I have no idea and repairability isn't one of my goals.
If the plane should need so much rebuilding that fuselage skins need to be replaced, I'll either hire a pro or part out the plane. But note that I'd take one of these approaches even if it wasn't bonded; I have no interest in that level of effort.
Dave
Old 11-06-2017, 11:56 AM
dwrichey's Avatar
dwrichey dwrichey is offline
I truly do not wish to rain on anyone's parade, but I wonder if allowing the adhesive to cure before the parts are riveted together would prevent the parts from properly "nesting" together. I assume the force exerted by the clecoe's is not nearly as great as those exerted by driven rivets, therefore leaving a thin layer of adhesive that over time could breakdown?
Old 11-06-2017, 02:02 PM
Folks, if you spot a potential issue with this or any other aspect of the construction, please let me know. I'm only human and I do goof sometimes.
Thanks for commenting.
The parts are dry-fitted together before gluing to verify a close-fit joint; and the edges of the joints are not sealed to allow excess epoxy thereby come out. Which it does, and needs to be removed.
Post-cure inspection of assemblies made so far does not indicate that there's a problem of this nature.
Dave
Old 11-16-2017, 03:04 PM
Before I could rivet the long belly skin, the side skins need to go on. The bottom of the belly skin was already riveted to the various stiffeners and bulkhead flanges, so the only remaining parts were at the ends and the bulkhead shoulders, and they can wait till I do the lower longeron and bulkhead riveting for the side skins.
The tape bumps roughly in the middle are folded-over tape, giving me aen easy place to grab on to for removing the tape. I now like 3M's model 33 electrical tape. I've tried blue painter's tape, which is harder to remove, and green painter's tape, which is fine if there's a wider area to tape but is slightly harder to remove. However the green painter's tape conforms down into the dimples better.
One of the steps to this gluing is to mask off the areas adjacent to where the glue goes and then do a dry fit check to verify that the tape is in the right place. At the upper left, you can see that I needed to adjust this a bit. The tape is slightly apart from the joint so that I can form the glue squeeze-out into a fillet there.
After a couple of intense days the left side skin was ready to install. I gathered up some friends and we began. About two hours later, we took these photos.
This is Dallice Tylee to the left and Dave Dooley to the right. They're both pilots; Dallice flies a Bonanza and Dave built a Xenos motorglider and also has a Swift.
And here's me. I'm pretty happy - we didn't screw it up.
Don't know if you noticed but we were all wearing gray shirts and jeans, completely unplanned. It wasn't a uniform, this was junk clothing that we could get glue on. As it turned out, we didn't - we used up a bunch of blue gloves, though.
If you're using epoxy and need to remove some from something, ordinary cheap vinegar works fine if the glue hasn't set up. Wash in vinegar, wash in soap and water, dry, done.
The skin has the exoskeleton on. This acts something like a mold, ensuring a smooth, fair skin. As soon as the glue is thoroughly cured, that comes off. Here's the skin with the exoskeleton on.
And again with the exoskeleton removed. There's still considerable clean-up to do at this point.
The photos can also be found here, here, here, here, and here.
Dave
Old 12-04-2017, 11:55 AM
After the gluing came the clean-up, and then the usual bunch of small things before anything major ever happens. Yesterday, though, Larry Larson came down from Estes Park, down to the valley, to help me rivet. You folks know him as Wirejock. His RV-7 is much higher build quality than my little RV-3B, so I was glad to have him over today.
We riveted the left side to the frame. We got all but the top longeron, of course, and we even managed to include the bulkhead shoulder rivets in between the lower longeron and those replacement bulkhead flanges that you saw earlier. So it was a good day.
He even brought treats. He bakes bread and brought me some really delicious sourdough he'd made. Yummy!
When we weren't talking about bread, he riveted and I bucked.
Some times the fuselage was tight and there wasn't much distance between the fuselage and the jig's side, and I had to work through the still-open right hand side. I suppose that I was doing it by feel since my eyes were wide shut here. It'll get harder when the right hand skin is on.
There aren't any photos showing me wholly inside the fuselage yet, but the various aches and sore spots assure me that I was really there.
We started with me inside the fuselage using a back-rivet set, and Larry outside using a fat back-riveting bucking bar. That went fine for a while and then I ruined several rivets in a row, and switched so that Larry used a rivet set outside while I bucked inside. These generally gave better shop heads. The factory heads outside were uniformly good, but of course the skin had been glued on so that its position was fixed. If you're gluing the skin, it doesn't matter which you use - use whatever technique works best for you. If you're not gluing, my experience yesterday doesn't apply.
If these photos ever disappear, they might be available here or here.
Dave
Old 12-04-2017, 12:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Ruveting fun
You're too kind and too critical of your build. It's a beautiful 3B.
I recommend everyone spend some time helping another. It is so much fun and a great way to practice perishable riveting skills. In my case it was an opportunity to give back some of what my Mentor, Dave, is so graciously given me. He even made an awesome sourdough rye for us to bring back home.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 01-17-2018, 07:37 PM
Seems like it's been a long time... in fact it has been.
The things I've done in the last month are small stuff. I'm getting ready to attach the next long side skin, and while it's still off, wanted to do some of the smaller stuff. These are things like riveting those bulkhead flanges that I made to the bulkhead's webs. These are finally done, along with a few less exciting things.
Since I'm waiting on a few things before gluing the side skin (it's the right one this time), I started on the belly skins under the seat. There are two of these, F-322, and they overlap both the spar bulkhead and the seat bulkhead, with two rows of rivets each. Drawing 23 shows most of the rivets, with Drawing 24, section A-A, as a supplement. Still, the rivets between the F-304 bulkhead, that short one in between the two center seat ribs, and the skin aren't mentioned anywhere that I could find. Here's a top view of the seat structure from Drawing 24, showing the bulkhead. Not being the bottom view, the rivets that are shown don't apply to the external skins.
I've been locating and drilling holes in the fuselage frame under the seat and in the skin. The right-hand skin there is now mostly drilled and clecoed. It needs some trimming, and yes, I know not to cut out the skin in the area aft of the rear spar.
I've been going so slowly that I thought a bit of motivation might be appropriate. I know that a lot of us put up photos of similar airplanes or sketches of paint schemes that they like. Other people display model airplanes... the list is long. Since I like, never, pay much attention to self-help posters, it occurred to me that the back cover of the 2017 Van's Aircraft calendar might be just the thing. By the way, friends, that cutaway RV sketch in the background is an early view of an RV-3, just as it should be.
We'll see if it speeds things up.
In case these photos disappear, perhaps the alternate photo hosting might continue to work. Perhaps. Worth a try in that event. Here are duplicates of these images:
https://imgur.com/tGyq3T1
https://i.imgur.com/L4zn2Ve.jpg
https://i.imgur.com/6EoEz5U.jpg
Dave
