Old 10-04-2017, 12:08 PM
mike newall's Avatar
mike newall mike newall is offline
Once you get your wrist calibrated, you can also use the 3 flute speed deburrer for all small countersinking up to #8 screws.
Takes a while to get the knack but saves a lot of time
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 10-04-2017, 01:44 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Originally Posted by sblack View Post
slow the speed way down
Thank you! My thoughts exactly.
Bryan
Houston
Old 10-05-2017, 06:57 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Debur
The Avery took is simple and works very well. I think you
Need to keep that tool and experiment with different debur cutters.
Al Girard, Newport, RI
N339AG
RV-9
Old 11-23-2017, 09:19 AM
Mort04 Mort04 is offline
Originally Posted by snopercod View Post
These work great and never chatter:
I?m having the same issue with chatter on my Empennage build. What do you use as a handle for these, or do you run them at low speed in a drill? Also what size is used for #30 and #40 holes.
Old 11-23-2017, 02:31 PM
Mudfly Mudfly is offline
I mostly use fingers with those. Sometimes I will slide a piece of short rubber hose over the shaft to get a better grip.
If you do use a power tool..very slow speed and very little pressure.
From my limited experience, I think I "over deburred" holes when I first started my project. Not trying to countersink, just "de-burr" the hole. It can be a fine line..especially on the thin skins.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2020 VAF Donation
Old 11-30-2017, 01:30 PM
StressedOut StressedOut is offline
I bought one of these to use with my single flute deburring bit I got from Cleaveland Tools. It's only $8! It can turn at speeds ranging from "very, very slow" to as fast as "slow". But hey, when you're deburring that's what you want, right? I also find it reduces fatigue (on you not the airplane) when you're deburring a large field of holes.
https://www.amazon.com/Decker-AS6NG-.../dp/B004HY3APW
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 11-30-2017, 03:25 PM
dwrichey's Avatar
dwrichey dwrichey is offline
I also had the chatter from new Avery three flute deburring tools. Tried faster/slower/harder/softer, got it to work better, but not great. Called Avery (when they were still in business,) he acknowledged the problem, stated basically it wasn't a significant problem, suggested one could lightly sand the cutting edge with fine abrasive cloth. Since I had several new ones, I tried sanding the edge, and it helped. Over time they seem to break-in and start working better!
