11-21-2017, 08:05 PM
Great looking plane. Congrats. What do you find the biggest difference between the -6 and the -7?
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
11-21-2017, 10:47 PM
Absolutely perfect. The dream unfolded in living color before my eyes.
congrats and well done!
Ben
2019 dues paid.
RV7 empennage acquired and the "journey" has officially begun. Wings are here!
11-22-2017, 06:20 AM
Beautiful Plane! You must have been very focused for a 14 month build!
11-22-2017, 07:44 AM
Congrats! Great paint scheme. Hoping for the first flight of my -7 this weekend if we get some good weather here in Northern IL.
Matt K.
RV-7 Tip-up - Flying!
XP Superior IO-360 w/cold air sump, Catto 3 blade prop
Garmin G3X
CFI, CFII, MEI
11-22-2017, 09:17 AM
The -7 flys just like my -6, however a very noticeable difference in directional stability, especially in turbulence, obviously due to the larger tail. Roll rate seems greater, but that may just be me. Also greatly improved ground handling with the 380x150 tires and Rocket link. I had a tip up on the -6 and the visibility was awesome. I am very pleased with the slider visibility and convenience, Super Tracks is a must for any slider installation.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
11-22-2017, 04:59 PM
Congrats! What a great looking airplane!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
11-25-2017, 12:07 PM
Sweet!
I'm building a -7 slider and I really like the looks of yours...Great Job.
Several questions.
Can we see the wings with a rear view? (I like the paint scheme and would like to see how the checkerboard plays out...is it on the ailerons too?)
Are those tires larger than stock? I like the wheel pants clearance.
Are you happy with the MT prop...Looks really nice.
Very inspiring.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
11-25-2017, 08:46 PM
Originally Posted by mfleming
Sweet!
Several questions.
Very inspiring.
I think this might be the angle you are looking for. Checkers are on the bottom of the flaps and both sides of the rudder. 3.5" squares. Tires are 380x150, which is slightly larger than the standard 5.00x5 but still fit the 5" wheel and standard brakes. Wheel pants have a generous opening in hopes of keeping them in one piece during soft field operations. 6 hours on the airplane so far and the MT has been amazing. It is unbelievably smooth. It is fairly light, so if you do go that route you will want to keep an eye on your tail weight during the build process. Our CG came out to be 80.62" empty which is well with in the 78.7-86.82 range, how ever once you start adding people and baggage it moves rearward fairly quickly. This is where a heavier prop would have an advantage over the MT if you end up with a heavier tail weight.
Jake
11-25-2017, 09:32 PM
Thank you for the photo...that was exactly the angle I was hoping to see. Great looking -7!
Also, thanks for the details on the wheels and prop...very useful information.
-M
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
02-17-2020, 01:49 AM
Can you share a pirep on the ZipTips please? They look really clean. Do they perform well? How was the quality as delivered and how much work was the installation process? Thanks!
RV-7
