Old 11-08-2017, 11:40 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Doc, it's the cost of the equipment (pressure pot rig) and the skill required to do it right with the "real stuff."
The approach I used is for non-surgeons
I'm happy with how it turned out, and would do it again. I'd encourage you to try it as well, unless pressure spray equipment is something you'd want to invest in anyway. I sweated a bit before I cut loose with the spray can, imagining having to sand it all off and start over if I botched it. Nobody likes scut work, right? But it turned out fine. In the end it was a confidence-builder.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 11-08-2017, 12:02 PM
snopercod's Avatar
Originally Posted by mciaglia View Post
why not just use the Zolatone products?
I'm guessing "price". The darn stuff is up to $168 per quart now, plus shipping. Disclaimer: I used Zolatone Apollo Gray on my interior and am very pleased with the appearance and durability.
(2020 dues paid)
Old 11-13-2017, 01:53 PM
Bill Boyd's Avatar
Default Still working in the top while it's off and accessible
Masked off the lift strut brackets and the window "faux trim rings." Matte black should go with most any upholstery scheme I come up with. Fingers crossed. These decor decisions I would prefer to put off till whenever, but they're upon me if I want to do this while access is easy.
No matter how careful I am with masking, I _always_ seem to find a way to point something at a gap and let 'er rip. I'll try to fix this little blem with a Q-tip and lacquer thinner later. There's clear coat underneath, so maybe I can coax the black overspray off of there. Might have to reapply gray with a toothpick to hide it, though.
Bill Boyd
Old 11-13-2017, 02:27 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Rather than lacquer thinner, try Goof Off. Paint store will have it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-13-2017, 07:48 PM
raabs raabs is offline
Goof Off would be easier to find..
Rob Kelly
RV-10 Under Construction
Old 11-13-2017, 11:28 PM
Mike S's Avatar
Senior Curmudgeon
Thanks, fixxed it
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-14-2017, 10:08 AM
Bill Boyd's Avatar
Default Removes a little TOO much
Tried the Goof Off first. As I feared it might, it cut right through every layer at once. I gained some practice in spot repairs... practice I'd need later in the evening's work session...
...when I realized that what looked like shadows in the aft area was actually black overspray that misted down on the rear portion of the canopy top, beyond the masking paper! (If only I'd tossed a drop cloth over the unmasked portions of my work piece that I assumed were out of the range of the spray can ) I set to work trying to do something about the "tan lines" I had just discovered <<in retrospect, clearly visible in the middle photo of my previous post>>. I knew (by now) better than to touch them with solvent of any kind. Dry rubbing with paper towels took about half of it off, and blended the transition lines somewhat between overspray and pristine areas. I thought maybe a paper towel wet with water would do a better job.
That's where I discovered that I had already rubbed through the matte clear enamel topcoat in these areas and made a second discovery: the black specks in the stone texture spray paint layer are water-soluble (this is why you aren't supposed to use this paint for outside projects without a protective clear coat). Carbon black smudges appeared everywhere. There was nothing else to do but carefully rub these areas down to the gray latex layer and reapply the stone paint and clear coat. Thankfully this was easier to blend in than I feared, and I'm happy enough with the result that I'm stepping back and leaving well enough alone. It's overhead and behind the passengers' heads, an area not seen except when loading the baggage area or judging a show plane, which this isn't.
I share this saga in the interest of full disclosure regarding the faux Zolatone process. It is inexpensive and easy, looks good when done right, and I believe it will withstand light use and careful cleaning of spills should they occur. It does NOT wear like nails (i.e. like real Zolatone would) and it's easy to screw up. I'd paint my window trim (or fabricate removable trim rings) first, before I did the faux finish. Easier to mask in that sequence and harder to mess up what's already done. I think if you baby this stuff it will serve well in non-traffic applications. It's not my recommendation for foot and hand traffic areas. Repairs don't appear complicated, except let's face it - if you have to fix this finish once the cabin top is installed, you're no longer working on the bench, but overhead, inside your (possibly otherwise-finished) plane. I hope never to go there.
Last night's experience does make me optimistic about the results I'll see when I have to blend the paint work I've already done inside the top with the paint that will go over the epoxy-micro that's going to fair the top into the fuselage sides around the door openings. I anticipate that the transitions between those two paint jobs will be hard to detect visually.
Do I wish I'd finished my top in shiny urethane that wears like iron but shows every surface imperfection? Tough call. I am having second thoughts. After making the front page with nice-looking photos, all I can do at this point is fully disclose how it's going. Each builder will have to decide whether they want to try this approach.
Bill Boyd
Old 12-14-2017, 02:04 PM
Bill Boyd's Avatar
Default Next step...
Firewall insulation and stainless steel foil. (Giving myself a little break from the fiberglass fun I've been having since April.)
Planning to use only one heat muff and valve on advice of several VAFers who say one's enough in the RV-10. This begs the question: which side are we on, boys? (Apologies to Arlo Guthrie).
Will use a Y in the SCAT inside the tunnel to serve both front and rear heat vents. Firewall is of course pre-cut for two heated air pass-throughs. Any opinions as to whether 'tis better to block off the left hole or the right?
I guess I'll have to secure some firewall-thickness stainless to patch the unused hole. Maybe McMaster.
Bill Boyd
Old 12-14-2017, 03:27 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Isn't this the stuff? $142 per gallon, not per qt.
https://www.autobodytoolmart.com/zol...g-p-31874.aspx
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-14-2017, 04:16 PM
snopercod's Avatar
Yes! That's the stuff! I was quoting Aircraft Spruce prices. Thanks for the tip.
(2020 dues paid)
