Old 11-06-2017, 10:27 AM
pvalovich pvalovich is offline
Default Mountain Flying - More Lessons Learned
Saturday afternoon passenger drop-off flight over the Southern Sierra Nevada Mountains from Inyokern (IYK) to Kern Valley (L05) - less than 30 miles. Wind 260/12 at IYK. Climbed to 8500 in clear skies to safely clear the two major ridgelines enroute. A little bumpy, but nothing unusual for the Southern Sierra. Uneventful leg - except noting winds were on the nose at 42kts at 8500 ft.
Return leg at 7500 ft. Fewer bumps than first leg until lee side of westernmost ridge. First roller banged my head off the canopy (thought I was tightly strapped in - but I was wrong) and induced an uncontrolled right roll. Second roller immediately thereafter continued roll with nose down pitch. Ended up about 120 degrees right wing down, 30 degrees nose low, accelerating. + 4.5, -3.1 g's on the g meter. This occurred within 2-3 seconds under clear skies, in pretty calm air with no warning.
Lessons learned:
1. Be wary of ridge crossings with high tailwinds.
2. Ensure you have enough altitude for recovery from nose low unusual attitudes.
3. Be comfortable with sudden unusual attitude recovery (I'm a former Navy A-4 Adversary pilot; joke about being more comfortable upside down than right side up).
4. If you suddenly find yourself nose low with excessive bank, roll wings level before pulling to the horizon - otherwise you risk increasing bank into a tight nose down spiral.
5. Be aware of your nose low airspeed - Vne is a real number.
6. Clear skies does not correlate to smooth air in the mountains.
7. Be wary - and prepared.
Old 11-06-2017, 11:06 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Good reminders Paul! Flying on the eastern slopes of the Sierra this time of year can be sobering - clear skies plus winds can mean...wham!!
We fly up and down the Owens Valley between Carson City and Big Bear a lot, and always try to be done with the trip by mid-morning if there are any winds at all. If we're forced to go when the winds are up, I generally stay well away from the Sierra (west) side of the valley, or fly low between the Mojave and Bishop. Those High Sierra are world class wave and roller generators!
I had an A&P exam at Fox Field last March, and it finished up about 0900. I coudl feel the wind coming up already, so I decided to go spend another night at Big Bear instead of heading up the Valley for home. Glad I did, as pilot reports for bumps got pretty severe that afternoon.
A man's gotta know his (and his airplane's) limitations!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-06-2017, 02:17 PM
snopercod's Avatar
Scary stuff. Foreflight has Turbulence Potential and Mountain Wave forecast charts, which I believe to be accurate.
(2020 dues paid)
Old 11-06-2017, 07:51 PM
Steve Melton's Avatar
wow, a +4.5g thump in Clear Air Turbulence (CAT). RV-9/9A is utility category (+4.4/-1.75 G). I'm reading "The Electra Story" and it is fascinating. It's a FREE Kindle book. Just certified by the agency, two brand new planes' wings fall off from CAT within two weeks of each other. In 1957 they allowed it to continue to fly but reduced the max speed from 400 kt to 225.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 11-06-2017, 08:10 PM
mchargmg's Avatar
mchargmg mchargmg is offline
Default Similar
Yes, after a similar incident, I went back to watching the upper winds when I fly around the mountains in Colorado. If they are above 25 knots at 12,000 or above I go somewhere else. Cuts down on my mountain trips, but it also alleviates my head hitting the canopy.
Geoff McHarg
2021 dues gladly sent
Old 11-06-2017, 08:48 PM
Robb Robb is offline
I had a similar experience over Utah last year. Hit my head hard and when I got back I ordered a set of harnesses with a crotch strap. I must admit my Husky takes the bumps a lot better probably because it goes a lot slower and has inertial reels in the seat belts
Old 11-06-2017, 09:07 PM
Originally Posted by RV8JD View Post
Well, not quite. The Electra's came apart due to Whirl Flutter.
I'm about halfway into the book and it's pointing towards CAT but now I know how it ends ( I asked for it )..... what the heck is whirl flutter? blades in resonance with engine whirl?
Steve Melton
Cincinnati, OH
Old 11-07-2017, 12:49 AM
skylor's Avatar
skylor skylor is offline
Default Whirl Flutter
More like wing resonance with propellor slip-stream..
It?s technically called whirl-mode flutter.
Old 11-07-2017, 01:25 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
The rule of thumb I was taught is a thousand feet of terrain clearance for every ten knots of wind. Above thirty knots, fuhgeddaboutit. I did most of my mountain flying over Arizona, and never had occasion to challenge the 10,000+ ft high passes in Colorado (had a converted Cessna back then.) not sure I wanted to.
At least take an online mountain flying course...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 11-07-2017, 04:56 AM
AttackPilot64 AttackPilot64 is offline
Default Mountian Flying
Mountian Flying can be an adventure for sure. Its important to learn about Winds and wind terrain analysis. Be careful on the leeward side of the mountain. That's were those downdrafts occur.
