Old 08-05-2017, 01:37 PM
Steenos Steenos is offline
Thank you Mr Vic!
Old 11-06-2017, 12:40 PM
bbt95762 bbt95762 is offline
Originally Posted by vic syracuse View Post
If your RV-12 is Amateur built, the operating limitations will state that only day VFR is approved UNLESS it is appropriately equipped IAW the FAR's for night and/or instrument flight. So, equip it properly and you can fly it IMC. Check your Operating Limitations. The new ones issued today and for quite a while have this verbiage mentioned above.
Vic
sorry, I got twisted, so assuming an RV12 is equipped for IFR
is the following table correct?
use IFR/VMC | IFR/IMC
type
S-LSA not allowed | not allowed
E-LSA allowed | allowed
EAB allowed | allowed
Brian.
Old 11-06-2017, 04:39 PM
Jetguy's Avatar
Jetguy Jetguy is offline
E-LSA not allowed | not allowed
Amateur built Equals EAB.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 11-06-2017, 06:46 PM
Mich48041 Mich48041 is online now
Why is IFR not allowed for E-LSA?
Assume pilot has a current medical and is IFR rated and current and the plane is IFR equipped.
Joe Gores
RV-12 Flying
Old 11-06-2017, 06:59 PM
See post 25. A DAR should know.
Old 11-06-2017, 07:14 PM
Larco's Avatar
Larco Larco is offline
I found this an interesting read regarding this subject
https://generalaviationnews.com/2017...ifr-in-an-lsa/
Larry
Old 11-06-2017, 10:13 PM
so that article say, if pilot is IFR rated and current, and if plane has minimum equipment...then yes IFR in IMC is ok....right?
does the RV-12 have pitot heat?
Old 11-06-2017, 10:23 PM
Azjulian Azjulian is offline
I'm just wondering where I could fit a GTN625 now on my 12 and how much work to wire into my G3Xs....
Old 11-07-2017, 05:55 AM
RV12JT RV12JT is offline
Considering all the above, that the -12 meets all the FAA requirements for equipment (Instrument Flight) and is an E-AB, what about the engine? Does it need to have a certified version of the 912 to be legal?
Old 11-07-2017, 06:00 AM
bkervaski's Avatar
bkervaski bkervaski is online now
Nope, just a certified panel mounted NAV source (GTN 6xx, etc).
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
