11-04-2017, 09:56 AM
Inside the cowl paint
What are you guys using for primer/paint for the inside of the fiberglass cowl and cowl atch strips?? Logic dictates that it has to be some kind of high temp paint, but the James instructions just say epoxy, so I'm torn. I really have no idea how hot it'll get under the cowl - I'm also running a plenum.
I still have a bunch of Akzo 463-12-8 and I love the stuff, but its not high temp. In fact I cant get a data sheet that says what its temp tolerance is. I bought some rattle can high temp engine paint, but its enamel and I vaguely rem that enamel cant take flexing.
Thoughts?
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
11-04-2017, 10:00 AM
Senior Curmudgeon
What I did...
Thin epoxy brushed on to fill, Vans reflective stick on foil over that.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-04-2017, 10:47 AM
I just did this - used epoxy primer to stick to the resin and urethane 2k top coat (white). Areas with hot parts near are getting vans reflective material and some 1/16" fiberfrax under the foil where the really hot parts are within 2". That cowl won't take a lot of heat and don't expect it to get that hot. Tg of the resin considered.
I can not say how well it works, but followed DanH's technique and he says his works well.
So one thing, definitely use the neat epoxy and squeegee it on to fill any and all pin holes and seal the weave. What ever you use won't look very good if you don't. If you want it really smooth, then finish (squeegee)with some micro, but it will take a lot of sanding to look smooth.
I know Will James was experimenting with some fine weave for the inside to facilitate a smooth surface. I got an early model with no core material and raw weave was easily visible. Maybe yours will be easier
Bill
RV-7
Lord Kelvin:
11-04-2017, 10:53 AM
I used West Systems epoxy with white pigment (Aircraft Spruce). I did not thin the epoxy but used a heat gun to warm the cowl a bit as I applied it.
Stewart Willoughby, 6 wiring/panel.
11-04-2017, 11:00 AM
My cowl is only a few months old, I have the core material. Not worried at all about the inside being smooth - is there something I dont know here? (my cowl outside is as smooth as glass - no pin holes etc, not sure if that was what you were referring to - its smooth enough to go straight to primer).
What is "neat epoxy"? Not heard that term before.
I like the idea of reflective and even fibrax in the obvious hot spots.....
Mani
N251Y (res)
11-04-2017, 11:50 AM
If your interior is smooth, and no pinholes, HURRAY!!! You are way ahead. Maybe all you want is a scuff, prime, top coat. I am wishing I had swapped with Will for a new one when he offered
Neat epoxy, no additives or dilution. I sounds like you won't need this.
The fiberfrax will go directly on the spots to be protected, and covered with the self adhering Vans reflective material. Other areas I am just using the reflective material direct to the paint.
Bill
RV-7
Lord Kelvin:
11-04-2017, 11:51 AM
Neat epoxy, meaning unthinined. Vans says to thin with some acetone to help fill pin holes, but if you work it around well with a squeegee it will fill without thinning and avoid potential weakening of the fiberglass from the acetone
E
11-04-2017, 12:43 PM
Ok thanks guys. Neat as in scotch neat. Not heard it allied to epoxy, but I get it now.
For sure you should have traded yours Bill. My top side cowl is smooth enough to see my face in it (not a pretty sight, but you get the idea!) The inside is a bit like an absorbent dish cloth in texture. Smooth in that way and also shiny, but not smooth enough for reflections. Both are devoid of pin holes - very much better than any fiberglass part with gelcoat Ive ever seen.
I'll scuff and prime with Akzo then and relieve Vans of some of that a reflective foil. Does it have a proper name and number, or just search Vans for reflective foil?
Mani
N251Y (res)
11-04-2017, 04:44 PM
heat shield, cowl
Bill
RV-7
Lord Kelvin:
11-04-2017, 05:07 PM
Three coats of white tinted epoxy (West Systems) with a tiny bit of acetone to thin looks like this after being rolled/brushed on.
Nice hard shell coating. Good visibility of any drips/leaks. Easy to wipe clean with some soapy solution.
This is before laying down the reflective aluminum and heat shielding from Van's.
More photos here.
