10-30-2017, 07:51 AM
Daily Musings .. nothing important
Well, it appears in addition to being a gymnast to build an RV you also need to be good at crossfit .. I'm sore as can be today from getting my wheel pants done yesterday. A constant drop, mount, mark, unmount, hop up, sand, repeat countless times for 10 hours
Also, I have a video camera setup to automatically activate when I walk in the shop to record my progress .. on more than a few nights I've been woken up at all hours by the compressor I forgot to turn off and have had to go down and shut it off .. hopefully dressed .. sometimes not .. sorry for whoever watches those videos and catches me stumbling in half or  mostly naked
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
10-30-2017, 08:09 AM
The physical impact of one of these builds doesn't get a lot of attention, but it can be significant depending on your age and physical shape. In addition to the pains you mention, I have a chronic case of tendonitis from years of hand work, cleco pliers, etc. Not to mention the blood I've left on different parts over the years from cutting myself. I used to tell my wife that if I wasn't bleeding when I left the workshop, it wasn't a good work session
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
10-30-2017, 10:55 AM
BUT---
its the education and recreation thingy. I guess the recreation is the workout you get during construction.
Tom
Ridgeland, SC
10-30-2017, 12:32 PM
 There's recreation??!!
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
10-30-2017, 12:43 PM
workout session
Numerous times, I've substituted my airplane factory episodes as my workout at the gym!
10-30-2017, 12:56 PM
My worst moments were when I was building the baggage door on my 8. You have to strap the door down tight to the fuselage and crawl under the instrument panel to drill and cleco the thing together, and then again to install the rivets. Well the problem is, I'm a good sized guy (Mostly around the middle  ) and I had to lay everything I needed on the floor right behind the firewall, then wriggle my hulk in, face up and arms above my head as there would be no re-positioning my arms after I was poked up in the nose; the gear towers being extremely limiting. Add to that the fact that the crotch strap mount is poking up from the wing spar. I put some foam and blankets in there to cushion it, but that sucker poked me seriously in the back the whole time!
So there I was, squirming on my back, arms extended forward over my head, strap mount digging into my back yelling "ow, ow, ow, mother &*%#@)&^!", all alone in the hanger, in the winter, and the heat is set to kick off at 9 PM! I truly thought I was just going to lay there, stuck, and freeze to death! My wife would have eventually missed me and tried my cell phone, but I couldn't have reached it in my pocket if I wanted to! Wouldn't have been a pretty picture with the EMS folks there sometime in the middle of the night, prying my fat, half frozen, rigor mortise stiffened magnificence out of that fuselage!
Yeah, that was my worst build moment!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
10-30-2017, 02:24 PM
To borrow from Larry the Cable Guy, "I don't care who you are, that there is funny!"
So, there must be a story in there about how you finally did get out!
10-30-2017, 02:54 PM
Been there, done that. And after all that work, I have discovered one of my wheel pants is skewed and I'm half-a-ball out in the cruise. I flew without (wheel) pants last week and could fly feet on the floor for the first time in 18 months.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
10-30-2017, 03:39 PM
The baggage door is ****, but the -8 pays back at wheelpant time:
Dan Horton
RV-8 SS
Barrett IO-390
10-30-2017, 05:43 PM
Super Moderator
Wait until you crawl back into the tail cone of a nose gear RV to replace an ADAHRS unit and forget to put a saw horse under the fuselage. Now you have to crawl UP, in reverse, with your arms above your head and no way to get them down.
Vic
 Vic Syracuse
www.Baselegaviation.com
