Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 10-27-2017, 06:10 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Thanks for the response, are you already including the new version with your quick panels, or is there a release date? Kirk had mentioned you were working on something but didn't have any additional information to share, this was Feb of this year.
Lynn
Originally Posted by N402RH View Post
  • You can configure the ACM to not run the flaps over a set speed.
  • The Autopilot power get wired to a separate power switch on the panel that you can shut off.
  • The trim has runaway protection
  • With the ACM-ECB you can turn off or reset any of the circuits.
Rob Hickman
Advanced Flight Systems Inc.
RV-10 in Process
Old 10-27-2017, 08:56 AM
N402RH's Avatar
N402RH N402RH is offline
Lynn
It will be an upgrade option on the Quick Panels, should be available in the next few months.
Rob Hickman
Old 10-30-2017, 11:50 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
The manual states that the AutoPilot IAS mode only works with the Dynon AP servos. I have the older AFS Trutrak AP and the IAS worked in previous versions. Is this functionality gone now? I see the IAS button is still enabled on the recent flight of mine, but is this no longer supported?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 10-30-2017, 11:59 AM
N402RH's Avatar
The Trutrak AP does not directly support airspeed climbs, the EFIS will convert the desired Airspeed climb to vertical speed and send it to the AP. It works ok for most airplanes. The Dynon AP has an airspeed climb and descend mode that works a lot better.
Rob Hickman
Old 10-30-2017, 12:02 PM
Ah, that would explain the so-so experience with IAS climbs I've had.
RV-10
N928MT
Build Project Site
