  #11
Old 10-24-2017, 02:01 PM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by NYTOM View Post
I finally have reached the stage where it's time to buy my battery.
Where's the best place to get the freshest PC680? I would hate to buy one that's been on the shelf for a year. Or in the case of the PC680 does it really matter?
Took a tour of a battery factory years ago and remembered the tech say that a batteries life ( lead acid anyway) starts the moment the plates are installed and to try to find the freshest battery you can find when buying one.
I got mine around this time in 2015 from BatteryMart with 10% off and free shipping (~$100). I wanted to use it when installing/testing avionics. First flight was Jan 2017 and I charged it periodically with an Odessey approved charger.
Wait for a Christmas special some time after Thanksgiving.
Gill ships their lead/acid batteries without fluid; maybe to retain the shelf life?
Ray
Old 10-24-2017, 03:22 PM
NYTOM NYTOM is offline
I can do that.
Thanks Ray
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 10-25-2017, 10:02 PM
lr172 lr172 is online now
I have been very happy with the PowerSonic AGM batteries. THey have a model with the same dimensions as the 680 and it is 18ah rated. They also have an HD version in the same size with a 20ah rating. I chose the later when I replaced it this summer. It has held up very well and only cost about $65 on Amazon.
Larry
Old 10-26-2017, 01:57 AM
Jermechanic's Avatar
Jermechanic Jermechanic is offline
Default Interstate YTX20HL-BS
Really happy with my Interstate Battery. 6years in my RV6 and going strong. I top it up occasionally with a battery maintainer to keep it happy.
Fairly easy to source locally. Around $130
Battery Family: High Performance, Maintenance Free
Battery Type: YTX20HL-BS
Voltage: 12
Capacity: 18
Dimensions: 6.875" x 3.4375" x 6.125"
Weight: 12.4lbs.
Metric Dimensions: 175mm x 87mm x 155mm
MetricWeight: 5.6kg
Polarity:
Acid Volume: 0.93
Amps: 1.8
C.C.A.: 310
Jeremy Prpich
C-GJZI RV6 Slider
Home base CYYJ- Victoria Int'l
Old 10-26-2017, 03:51 AM
Abbygirl1 Abbygirl1 is offline
Thumbs up
Originally Posted by rv7charlie View Post
The PC680 has become the defacto standard for a lot of us. But if you're willing to look a little deeper, there are other useful options. I've had one similar to this:
https://www.apexbattery.com/ub1220-1...AaAtXyEALw_wcB
in my 160 HP -4 for about 4 years now, and I've used the 18AH versions for the previous couple of decades. Four to six year life, and the batteries tend to sit for weeks at a time because I don't fly much.
One potential advantage to the 22 AH size batteries like the link is that if you have an electrically dependent a/c, it has significantly more total energy than a PC680, which is a 16 AH battery (meaning longer duration with normal electrical loads in the event of an alternator failure).
If you're one of those who needs the brand-name for confidence, go with the PC680, but if you're value-oriented enough to do more research, these 'no-name' batteries are worth a look. They have the same AGM technology as the PC680. The primary difference is that they are optimized primarily for continuous load, instead of starting. But they still have more than adequate 'CCA' numbers for cranking our engines.
The 22 AH models have an almost identical footprint as a PC680, but they are slightly taller. Do your homework before purchasing; neither is a physical drop-in replacement for the old wet cell lawn tractor or a/c batteries we used to use.
Charlie
Charlie,
Just ordered the one you referenced. Looks like it should work fine. Mine is mounted in between the rudder pedals.
Dad of an Air Force C-17 flight instructor
Old 10-26-2017, 06:52 AM
ABRV4 ABRV4 is offline
I've been using the PC625 in my 160 hp -4 for years. It is slightly smaller and lighter than the PC680 and is more powerful.
Old 10-26-2017, 07:12 AM
rocketbob's Avatar
http://www.gruberpower.com/12-volt-1...our-ah-battery
I have these flying in a few airplanes I maintain and they have been flawless. Better performing than the PC680's they replaced.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-26-2017, 07:42 AM
Sam Buchanan's Avatar
been here awhile
I have also used the less expensive AGM batteries in the RV-6 and now have one in the Fokker replica. However, keep in mind the terminals are not as robust as the ones on the PC680, so good installation practice includes assuring the terminals are not stressed by poor cable orientation or lack of support. But the batteries are a good value in many aircraft applications.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 10-26-2017, 07:59 AM
rocketbob's Avatar
The terminals are plated steel on the Gruber batteries. You could probably lift the airplane with one of the terminals if the battery is strapped down well.
N8155F C150 flying
Old 10-26-2017, 09:19 AM
This one looks identical to the Powersonic, so I would guess it comes from the same manufacturer, whoever that is.
