Old 10-20-2017, 10:53 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Default Tailcone fairing clearance issue
I am facing a clearance issue between the stabilator skin and the empennage fairing mounting screw. The issue is on both side, so the fairing is centered well.
Apart to this the fairing fits nicely.
My idea is to slightly trim the skin to gain clearance, but I d'rather ask the experts here what is best to do before I proceed.
Thanks for any inputs on this
Chris
[IMG][/IMG]
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 10-20-2017, 11:17 AM
D&M Dan D&M Dan is offline
I used a sanding block with 80 grit paper and worked the edge so it appears to smoothly transition and clear the screw. I don't think I would notch it like that.
RV12 Flying
Home Field KSDC
Paid 2019
Old 10-20-2017, 12:03 PM
Rrhsch Rrhsch is offline
Remove a screw on both sides of the fairing and run a safety wire folded in half between the two sides. I used a nail and washer to hold the wire on each side. Twist the safety wire against the nail to pull the fiberglass in just enough to give you clearance plus a little over bend. Then use a heat gun and gentility heat a LARGE area of fiberglass on both sides. Heat until it is too hot to hold your hand on it but not hot enough to burn the glass. Let it air cool to room temperature, remove wire and it should retain its shape. I did this with mine and it worked.
Old 10-20-2017, 12:45 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Not building a 12 but couldn't you use a countersunk screw/tinnerman instead to give clearance?
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-20-2017, 01:04 PM
sf3543 sf3543 is offline
Default I had the same issue
Just installed countersunk screws and everything worked out fine.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 10-20-2017, 08:39 PM
rk2436 rk2436 is offline
I just moved the whole fairing a touch forward and it solved the issue. Most -12's that you see you can tell they trimmed the HS skin half arsed.
Old 10-20-2017, 09:14 PM
DaveWelch DaveWelch is offline
Default Clearance
Hmmm...I see clecoes.
I?d recommend that you get both fairing halves mated up and finish mounting in their final position before trimming the stabilator skins or making other adjustments for clearance.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 10-20-2017, 09:40 PM
I had to trim the skin on one side when I built it. Later my stabilator bearings started slipping horizontally causing the skin to catch a screw head. Once I did the SB to threadlock the bearings I had no issues.
Old 10-21-2017, 02:06 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Trimmed the stabilator skins and made a bracket to make the tailcone more rigid:
PH-BZT
MyKitlog
Old 10-21-2017, 02:14 PM
dbhill916 dbhill916 is offline
That looks very interesting. What kind of effects did it provide for you? Do you have a drawing of your bracket?
thanks,
-dbh
David B. Hill
N76012
RV-12 #0760
Dues paid through 6-2021
