Old 10-17-2017, 04:11 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Default C-01426 Canopy Latch Pin
Hey guys, is the C-01426 Canopy Latch Pin supposed to be flush when retracted or does it protrude a bit? By the book, mine sticks out about 1/4.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 10-18-2017, 04:41 AM
Ron B. Ron B. is offline
The very tip does stick out a little bit but not a 1/4". It certainly does not touch the canopy blocks.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 10-18-2017, 08:39 AM
KeithB's Avatar
KeithB KeithB is offline
Approx. 1/32"
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 10-18-2017, 08:40 AM
bkervaski's Avatar
Thanks for the replies!
@KeithB Curious, why did you flatten our your point?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 10-18-2017, 09:38 AM
Jake14 Jake14 is offline
Just approximate it for now, then when the canopy is installed, make the final adjustment to just clear the plastic blocks on the canopy frame when closing, then adjust the micro-switch to trigger the warning
Old 10-18-2017, 11:25 AM
Nova RV Nova RV is offline
Mine matches Keith's measurement
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 10-18-2017, 11:34 AM
Don E Don E is offline
Default Mine protrudes 1/8?
But clear everything.
Old 10-18-2017, 04:06 PM
KeithB's Avatar
@bkervaski:
Unmodified - just way it came.
Keith Brown
RV-6A sold
Dues paid 9/2020
Old 10-18-2017, 04:35 PM
bkervaski's Avatar
Weird. Mine are pointed.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 10-20-2017, 11:51 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
My pins look just like the one in the Keith Brown photo, the tip is shaved off to an approx 1/16" blunt end - that's how they came.
When my canopy latch pulls the pins in, the end of the pins are recessed behind the plate about 0.25 mm.
The only thought I have is that your C-01430 Latch Bellcranks are installed upsid'zy down.
Another thought today after looking again > More probable, the adjustment of the rod end bushings each end of the torque tube between the canopy latch handle and the bell crank that operates the pins.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
1946 Bellanca Cruisair 14-13-2 (73 YRS OLD 8/15/19)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/1/19 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
