10-18-2017, 07:35 PM
I am OK and Thanks
Departing Othello WA October 14, 2017 with full fuel I decided to test the frangible connectors of one of their PAPI unit boxes. They work. Unfortunately the connectors and the PAPI unit box didn't survive the test.
I also thought I would test the structural strength of my right wing and fuel tank. The fuel tank failed but the wing passed...almost.
I also decided to do this test with my wife in the back seat to test her reaction to stress induced by fuel spewing out from under the right wing. She passed but just to make sure I declared an emergency.
On a more serious note, even though my takeoff was a complete fiasco, the RV8 took an incredible hit and yet held together long enough for us to safely land 30nm away as if nothing had happened. Sitting on the ramp she shows no indication of the abuse she suffered at the hands of her pilot. It is only when you look underneath the wing that things look different.
My wife thinks I handled the situation 'very professionally' but truth to tell, professionals generally prefer to stay on the runway during takeoff.
I would like to thank everyone for their help and concern. Special thanks to the Air Traffic Controllers, the pilots on the radio, and especially Grant County Approach and Tower. A special thanks to the MillionAire Club and Columbia Pacific Aviation (CPA) at Grant County International (KWMH).
At this point in time, the Starboard (right) tank is toast, the flap has a repairable gash on bottom, the elevator fiberglass tip needs to be repaired/replaced and the spar is slightly deformed in one spot near point of impact. Other than that my RV8 is OK and yes it flies fine on one tank.
The wing root shows no sign of damage including the tank flange which has the break away modification. The internal spar bolts have undisturbed torque seal and there is no obvious skin distortion on the wing.
The fuel tank punctures (2 of them 1' apart roughly 2" square are directly next to the spar leading edge and in front of the two inspection panels. With these panels removed, there is no sign of spar damage, but the front of the spar (with fuel tank removed) tells a different story. The deformation is slight, but to me (And to Vans) the spar is compromised and thus not airworthy.
I will post some pictures to my blog site when I am up to it.
Where do I go from here? Well, I have sent some pictures to VANs asking about spar repair/replace options. I will be scanning the forums for posts from those of you who have tread this depressing path. So far I have done little other than respond to information requests from the FAA, insurance, etc. and look at very used and grossly overpriced GA aircraft pictures/videos with horrid antique panels.
I refuse to end with 'be safe'. Point of Fact is that none of us sets out to have an accident. Instead, I wish you all 'good landings'.
Regards,
Vince Himsl
RV8 N8432
Reason: more accurate and updated damage assessment
10-19-2017, 08:14 AM
Looking at the pictures on your blog and thinking of the spar replacement, I think it would be just as easy to build the entire wing again. They do go together pretty quickly...
10-19-2017, 09:17 AM
That is VANs Assessment
VAN's told me that as well.
I am also checking to see if I can get a quick build wing from VANs.
Vince
10-19-2017, 05:32 PM
and that is a really clean spar. bummer.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
10-19-2017, 06:07 PM
Abort!
Please, Please, Please..don't continue a takeoff after you've hit something. Chop the power, pull the mixture, fuel off, master off, ignition off and GET OUT! Assume the plane is leaking fuel and you've got a major fire hazard. Assume that the aircraft has been structurally compromised and won't make it into the air, much less 30 miles. You're very lucky. It could have turned out much,much worse for both of you. Glad that you survived to talk about it.
Terry, CFI
RV9A N323TP
10-19-2017, 09:47 PM
Testing
Thx for sharing your testing! I don't think my wife would of have passed that part of the stress test as well as yours. I'm sure I would have recieved so many wacks on the back of my head that I would not of recovered.
Glad to hear your wife and you are OK The plane can be repaired and life moves on.
Try not to beat yourself up to much. You encountered a problem, kept your cool, dealt with the problem and landed. Good Job
Rod Estep
RV8, BPE IO-360, C/S
5yr build, 10yr Flying
Still Grinning!
Dues Pd
10-19-2017, 10:22 PM
Terry, CFI
RV9A N323TP
Every situation is totally different, and there is no single answer. You cannot simply say "abort every takeoff if you hit something" as there is many reasons an aborted takeoff could be much, much more dangerous.
I really admire the OP for sharing his experience, as experience is how we all learn. Thank you, and best of luck with the repair process, please keep us up to date.
Sounds to me like the situation was handled very well given the circumstances. Don't let the armchair quarterbacks tell you otherwise.
Alex
Alex Doughty
Canadian ATPL
Flying!!
10-20-2017, 12:41 AM
Thanks for sharing!
Originally Posted by cougar8
... I refuse to end with 'be safe'. Point of Fact is that none of us sets out to have an accident. Instead, I wish you all 'good landings'. ...
Vince, thanks for sharing the story, really happy to hear it turned out ok. It's good to know I'm building a tank!
10-20-2017, 01:01 AM
Some additional info
I have 500hrs total time; 200+ hours in my RV8.
I don't mind the arm chair quarter backing. I have done it myself. Problem is, the accident (and the problem) began when I lifted the tail, maybe even before.
I will be filling out the NTSB report sometime this weekend. After that I will add some comments about what I think (and most of you probably suspect) happened.
The FAA inspected my RV8 and I found out that the difference between an 'incident' and an 'accident' is whether or not there were injuries (no) and whether there was damage to a major structural component or assembly. As the spar is a major structural component, my event is officially now an accident. Also, when there is an incident/accident the plane is under the control of the FAA and NTSB until they release it.
VAN's is pretty straight forward on any spar damage...the spar has to be replaced. They do not sell parts for the spar. Bending back in place although tempting is not an option.
My friend suggested I approach VAN's with an offer to give them my damaged wing in return for a discount on a new one. Anyone tried that?
Moving forward, I have the older (cir. 2004) style spar/wing but Van's says I can slide in a new quick build wing. I may consider just rebuilding the wing, but for me, building the RV is something I only wanted to do once.
Again, 'good landings'
Vince
Reason: NASA should be NTSB
10-20-2017, 09:07 AM
So nice to have shared this incident
This was well worded and as such made it painfully obvious to this reader it was something that could easily happen to any pilot!
Also pointed out the fact that it was :
1/ manageable and well managed
2/ survivable and that you did in fact survive the "incident"
Not many would post this for fear of reprisals and arm chair pilots offering what should have been done.
Thanks again and it did entrench in me that I am building a pretty stout aircraft and that when stuff happens a good pilot can expect this plane and his cargo to survive!
Dave
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
