Old 10-18-2017, 05:27 PM
Art_N412SB's Avatar
Art_N412SB Art_N412SB is offline
Question Rotax 912ULS Idle speed to high
Hello friends,
I am new to the RVs and the Rotax engines. As a matter of face after 50 years of professional aviation this is my first aircraft ownership. I picked a great airplane to buy into. 3 of us own this RV12. I have had 4 flights in it and am in love.
So this week finds us doing a 100/200 hour inspection at 400 hours of airframe time. The engine ran flawlessly going into the inspection. But when we rolled it out to do the carb sync, suddenly the idle rpm went to 2500. We are having a tough time figuring out what the difference a day would make.
Let us suppose that we went through all of the obvious things. (which are not obvious to me) and we decided to do an idle speed adjustment. The Rotax maintenance manual 10.5 Idle speed adjustment procedure refers in step 1 to adjusting the idle mixture screw. Is that a factory only adjustment? Do you guys ever adjust the engine idle speed using this screw in addition to the idle speed adjustment screw of the throttle valve?
Thanks a bunch,
Art
Old 10-18-2017, 05:38 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Did you mess with the carbs in any way during the inspection?
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 10-18-2017, 06:05 PM
Ernie Ernie is offline
Any adjustment to the throttle cable threads will likely require readjusting the idle stops. Recommend you watch the Carburator Syc video at info@rotaxowner.com
Old 10-18-2017, 08:10 PM
You can adjust the idle mixture screw, but at the ROTAX course the guy told us most people who mess with it cause more issues. The ROTAX manual tells you to set it by screwing it in and then backing off a set number of turns I think 1 1/2: but I don?t remember for sure. It should have been set at the factory, and unless you changed it I wouldn?t mess with it.
Old 10-18-2017, 08:32 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
1 1/2 turns is correct...
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 10-18-2017, 08:45 PM
Driftdown Driftdown is offline
Excellent suggestion.
Old 10-18-2017, 09:50 PM
Azjulian Azjulian is offline
check the idle stops (the brass stops that you lock in position with the tiny allen key) its easy to have those setup to prevent you getting to a low enough throttle cable position.
Old 10-18-2017, 11:20 PM
Art_N412SB's Avatar
The only thing we did was to remove, clean, and replace the filters.
Old 10-18-2017, 11:22 PM
Art_N412SB's Avatar
Thanks, I will watch the video. I looked at one on Youtube of a complete overhaul of the carburetor. That was pretty interesting. Took about an hour though.
Old 10-18-2017, 11:23 PM
Art_N412SB's Avatar
We adjusted the idle stops to book specks, with no luck.
