Go Back   VAF Forums > Main > My RV Build Project
  #11
Old 10-17-2017, 09:15 AM
rvbuilder2002's Avatar
Taylor,
Quit wasting time with trivial stuff like building airplanes and get your school work done so you can get back to work.........
Looking good by the way, but it looks like a few of those skin stiffener rivets are under set
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 10-17-2017, 06:48 PM
jcarne's Avatar
jcarne jcarne is offline
Originally Posted by Tdeman View Post
I've been scuffing lightly with scotchbrite, then using a damp rag, followed by a rubbing alcohol-soaked rag to remove debris/grease. The alcohol doesn't seem to cut the red lettering as hard as acetone would, however an extra pass or two does in fact remove it.
Perhaps I should switch from alcohol to acetone?
I'm sure an alcohol wipe is good, I think the point is mainly to remove oil residue from anywhere on the skin. I use acetone as it is superior at this (and because that's what everyone else does) I am surprised that alcohol doesn't remove the lettering, interesting...
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 10-18-2017, 10:30 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Working in the kitchen - good job! I hope that continues to work well for you!
Our biggest regret rebuilding after the house fire 2 years ago is not putting the shop "off-campus" out in the yard. I can't run any tools or even accidentally drop a wrench without waking the wife sleeping overhead in our first-floor master. And the fiberglass dust and aluminum shavings that get tracked upstairs despite the doormat and the carpeted stairs drives us both crazy - mostly her. I make a lot of runs up and down the stairs in a typical work-session evening, so taking my shoes off as she suggests would gobble up a lot of work time, which as for many of us, must be carefully regulated and apportioned so as not to neglect wife and children.
Despite the downside to a backyard shop (long walk in the dark, need to run power and water, the big air conditioned and heated basement was already there needing only interior finish) I do wish I had done it - my useable work hours would be so much greater. There was the psychological perception that being right downstairs was not as far-removed from the family hearth when everyone else wanted to veg and watch TV, but that's an empty premise in retrospect.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Last edited by Bill Boyd : 10-18-2017 at 09:18 PM. Reason: can't spell "far" on frst try
Old 10-18-2017, 03:18 PM
Tdeman's Avatar
Tdeman Tdeman is offline
Despite the downside to a backyard shop (long walk in the dark, need to run power and water, the big air conditioned and heated basement was already there needing only interior finish) I do wish I had done it - my useable work hours would be so much greater. There was the psychological perception that being right downstairs was not as for removed from the family hearth when everyone else wanted to veg and watch TV, but that's an empty premise in retrospect.
Only work done in the house is the photowork! Everything else is either done in the hangar or the garage. (Except for leading edge rolling. I chose to wrestle those on the carpet where any sliding around of the rudder would not result in scratches on the skin.)
This post brought to you in part by, pour-over coffee, sleep deprivation, and a need for speed.
Opinions expressed in this post do not necessarily represent those of my employer.
Old 10-18-2017, 03:42 PM
Tdeman's Avatar
Taylor,
Thanks Scott!
One of my early rivets cracked on a 45* shear plane literally minutes after analyzing a similar compressive failure in class... I considered that build session "further research of in-class topics."
Old 03-25-2018, 02:08 PM
Tdeman's Avatar
Default Change of pace (and project)
While browsing the VAF classifieds in January (for one last time before pulling the trigger on a factory QB 7 Fuse), an RV-6 project popped up at a near-quick build stage. A few phone conversations and a week later, a good friend of mine and I made a morning of flying out to Orcas Island to check it out. After looking it over, I decided it was a project I wanted to take on and ideally, be the one to finish.
Checking out rv-6 by Taylor de Man, on Flickr
It was an early 90?s shipped RV-6 that had changed ownership a couple of times, had relatively good workmanship, and was out of all (the big) jigs.
After arranging a truck for pickup, checking the ferry schedule and regulations to the island, and getting the space ready at home, I finally made the trip to pick it up.
RV-6 Pickup by Taylor de Man, on Flickr
The shared garage at home accommodated an empennage build previously, but I decided this project was ready for the hangar. With the hangar just 5 minutes from the house, and right on my way home from work, I?m hoping the whole ?offsite build? doesn?t slow things down too much.
The first week of evenings was spent organizing and inventorying parts, as well as making the hangar a build-friendly (see: lights) environment.
IMG_7816 by Taylor de Man, on Flickr
With all things in place, yesterday was the first day I was really able to get some work done on the project?
Old 03-25-2018, 02:37 PM
Tdeman's Avatar
Default First day of work
While there are some things I’ll need to go back and correct (possibly the firewall recess for example), I had just recently put together the sub panel structure on my dad’s RV-9, and decided to tackle that first while it was fresh in my mind.
With no prepunched holes, it was a series of careful measurements, double-checking measurements, cutting/drilling, checking fit, adjusting, repeat. I first fit the sub panel for height, level, and straightness. Drilled through the two halves and side mounts so it could be cleco’d in and out of place easily.
First day by Taylor de Man, on Flickr
From there, marked and drilled the holes for the ribs on the firewall, then transferred the holes to the ribs themselves. after some measuring, the sub panel notches were cut to allow the ribs to pass through.
Some more lining things up, checking for straightness etc, and the angle brackets were made and drilled in place for the outboard ribs.
Still need to make the center rib bracing and roll-bar brace mount, but it felt like a productive first day, and was nice to see some progress made on the project.
Old 03-25-2018, 05:08 PM
RV7ForMe RV7ForMe is offline
Nice shop and looks like you found a nice kit! Keep the pics coming.
VAF dues paid for 2021
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 03-25-2018, 06:53 PM
kentlik's Avatar
kentlik kentlik is offline
Nice workspace! I can only dream of such things...
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-25-2018, 07:03 PM
Doug's Avatar
Doug Doug is offline
Well that acquisition just kicked you town the track by a year or four. Great workspace.
Doug Gray
RV-6 completed, flying since July 2010
