04-23-2007, 09:41 PM
Get the Claw
The Claw kit is well worth the money. Everything you need is there incuding tie down line. The stakes come out with almost no effort. Together they hold better than most anything out there. Living in the land of thunderstorms where roll clouds can pack a powerful punch, I want the best hanging on to my investment.
http://www.aircraftspruce.com/catalog/pspages/claw.php
RV8 "Gladder's Gal" #80707
Superior IO360 B1B 193 HP, Whirlwind 151-69"
IFR-Dual Cheltons, Crossbow NAV 425EX
Garmin 430/SL30/330 Mode-S w/ traffic
Ryan 9900B TCAS, WSI AV300, S-Tec 55X
Searey 80 HP
04-23-2007, 09:56 PM
Ditto...I tried out a set of the "claws" and bought a couple more sets for friends. I'm to lazy to build my own, and their little kit of tie downs is just great! I can wholeheartedly recommend them (even if you can build a set of your own cheaper).
Stein
RV6, Minneapolis
04-24-2007, 07:15 AM
tie downs
I made some very slick ones a couple years ago. I can't claim credit for the design. I copied a vintage plane anchor contraption at SNF a few years ago.
Stop by the junk yard, ( where all good projects commence), and pick up a chunk of a plastic roller. They are used on conveyor systems in industry. They are about 3 inches in diameter.
Slice up in 1" thick 'hockey pucks".
Drill and countersink a rope sized hole in the center.
Drill 3 angled holes for the pins around the top of the disc.
The angle is not critical. You just want to grab as big a hunk of soil as possible.
I used alum tubes for the pins to keep it light.
Installation:
set the disk on the ground with the rope fimly attached under the wing or tail.
Drive the 3 pins.
Tie rope to plane.
complete.
I cross drilled the tops of the pins and put small clipon pins so I could pull the pins w/ a claw hammer.
Its all very light and rolls up into a skinny bag.
cary rhodes
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
03-17-2008, 04:49 PM
Thread Revival
Can anyone reference the EAA Sport Aviation month and year that the tie-down article appeared in?
03-17-2008, 05:09 PM
Moderator/Tech Counselor
Try this link:
http://www.vintageaircraft.org/magaz...ft_tiedown.pdf
If it doesn't work, go to EAA AirVenture, look under pilot info and you will see a tying down link and a link in the article to the tiedowns.
They work Great as I made a set, too.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
03-21-2008, 01:05 PM
Thanks for the reply, but that is not the article I was looking for. Edit: Now that I look at my first post, it was pretty poorly worded.
Two calls to EAA later, and I have my answer. (The people at EAA are very helpful.)
Sport Aviation, April 2004, "Building a Better Tie Down," page 110
The advantage of the tie-down described there is that no metal cutting is required, and it's straight simplicity.
PM me if you would like a copy of the article.
04-04-2008, 12:45 PM
16" Super STake
I just returned from Lowe's Aviation Supply and Feed Store where I bought three of these 16" Super Stakes for $3.97 each.
These stakes tend to hold well in sand but can be a pain to stick in the ground where there are rocks or hard pack dirt.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-04-2008, 04:23 PM
Originally Posted by caryr
...Stop by the junk yard, ( where all good projects commence), and pick up a chunk of a plastic roller. They are used on conveyor systems in industry. They are about 3 inches in diameter.
Slice up in 1" thick 'hockey pucks"...
cary rhodes
Funny you should mention this. I've seen actual hockey pucks also used for this application. Simply drill three holes at an angle through the puck for the retention rods and a hole through the center for an eye bolt to attach your tie down rope (or just a hole for the rope). It eliminates the need for any welding.
Doug
RV-6, AT-301, G-164, C-188...
12-20-2012, 01:29 PM
Tiedown easy removal
Be careful when choosing a tiedown. All systems have their pro?s and con?s. Things to consider. 1. Ease of removal - Flyties have special pull device that slips under the steak head to allow removal with minimum effort. 2. Tiedowns must be used as instructed. The Claw system works, but any side loading can result in failure. See video produced by Storm Force ( http://www.youtube.com/watch?v=X2UC5...eature=related ).
12-20-2012, 02:49 PM
Forum Peruser
Old topic with some recent postings
Do a search on "tie-downs" in these forums and you'll find several, more recent discussions of "tie-downs."
A moderator  should probably spend time to merge these threads as they show up in "General Discussion," "Safety" and "Reviews" forums.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
