Old 03-14-2016, 04:46 AM
salto salto is offline
Default Flap actuator alignment tool.
The flap W-00026 alignment template section 34 pg 02 doesn't seem to be in the fuselage kit. Doesn't appear on the parts list either. With the prefix of W- does it come in the wing kit?
Could someone shed some light 💡 on this please.
Thanks.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 03-14-2016, 06:26 AM
Tom023 Tom023 is offline
W-00026 is in the wing kit. Used on page 23-10 to align the ailerons.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 03-14-2016, 06:56 AM
Thanks Tom23 seems odd that it's not included in the fuselage kit also as it's used to drill the flap actuator and called for in the plans.
I've got my wing kit here ( not unpacked yet) so I'll rummage around and see if I can find it.
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 03-14-2016, 08:16 AM
KeithB's Avatar
KeithB KeithB is offline
This indeed comes in the wing kit. It is used several times in the plans at various points in the build.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >600 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 03-14-2016, 08:54 AM
rvbuilder2002's Avatar
And is the reason a specific kit purchase order is listed on the order form...
It may not officially state that is the designed/intended construction order, but it is.
There are numerous construction manual build details that to work, require that a specific build order be followed.
Scott McDaniels
Hubbard, Oregon
Old 03-14-2016, 02:49 PM
Thanks Keith and that's a salient point you make Scott which I wasn't aware of.
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 10-16-2017, 12:01 PM
mturnerb mturnerb is offline
I just discovered this interesting problem. I'm ordering QB wings - so I guess I'll call to see if I can get a template....
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 10-16-2017, 01:15 PM
Logan Logan is offline
Yep, you do. One came in my QB wing kit.
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
Old 10-16-2017, 09:32 PM
Richard Connell Richard Connell is offline
Scott, I?m building a 10 and am fiddling around with rigging the flaps and ailerons on the wings ahead of doing the tips.
Given the similarities between the -14 and -10 airfoil would it be appropriate to use the W-00026 to set neutral for a -10? Just curious. Looks a little more robust method.
Cheers
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 10-16-2017, 09:47 PM
Cheers
Yes, the same gauge tool should work for the RV-10 as well.
Scott McDaniels
Hubbard, Oregon
