Old 10-16-2017, 04:21 PM
terrykohler terrykohler is offline
Default Mount A COMM Antenna Under the Wing?
When I re-did my panel, I left my wingtip Marker Beacon antenna intact. Easiest would be to replace it with an archer COMM antenna, but the reviews on this forum have been less than stellar. BTW, The Archer VOR antenna works great
I would like to use the coax already in place, so I'm now thinking of mounting a conventional antenna under the wing rather than the fuselage.
Is this a good or bad idea? Reasons?
Terry, CFI
RV9A N323TP
Old 10-16-2017, 06:41 PM
gasman gasman is offline
Bad idea...... The wing is much harder to access to install a doubler to support the load on the antenna.
The Archer VOR works great because you arn't asking it to function in the wrong position.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 10-17-2017, 07:13 AM
Raymo's Avatar
Raymo Raymo is offline
I don't see a reason, other than aesthetics, why you could not mount it under the wing or on an inspection panel. It will, as the previous post mentions, require a doubler.
I have my Dynon heated pitot/AOA tube mounted on the outermost inspection plate. Same concept.
Ray
