10-12-2017, 10:07 AM
Lycoming in place of Subaru
Seeking advice from others that have made the switch. N447BB first flight cut very short when Subaru 2.5L suffered sudden internal failure. Fortunately airplane and pilot safe in a nearby cow pasture.
Have decided to not repair the Sube, but will instead install a conventional Lycoming.
10-12-2017, 01:40 PM
Good idea.
It would help to know what kind of RV we're talking about, where the third wheel is, and what your mission is (aerobatics, travel, mixture of both).
Rob Prior
10-12-2017, 01:48 PM
Caleb Lesher here on VAF, changed out his EZ30 for a Lyc. He's got some nice inspirational photos here: http://www.vansairforce.com/communit...d.php?t=147198
Piston failure on the Subie?
10-12-2017, 02:03 PM
I removed the Subaru conversion from my project after a friend who had bought from the same supplier suffered a mid air failure over dense woodland. Happily he survived mostly uninjured but the aircraft was wrecked. This was the last straw for me with a conversion that was full of bugs and had been horribly misrepresented and oversold by the supplier.
As it was already mounted I had to remove the whole thing cover it in a tarp and stick it in the corner of the workshop. That was the easy bit.
The I found a decent supplier, in my case aerosport, and ordered a real aero engine. Then I contacted Vans and with their help ordered the parts needed to attach it. It wasn't a cheap exercise and put me back years in a build which I hope is now approaching completion.
If your current engine mount pretty much is made to the right pattern then bolting up the new one should be fairly straight forward. Then you have all the usual engine fitting challenges like baffles and cowl work to deal with.
Good luck
Peter Costick
Melbourne Australia
RV7A Flying, VH-SVN
2020 Donation Made
10-12-2017, 02:25 PM
Conversion
Your current electrical system and fuel system are a good basis for an aftermarket FADEC on a Lycoming. SDS for example.
-Andy
Andy Simpkinson
RV-9a Subaru engine.
Reason: Wording
10-12-2017, 02:50 PM
Lycoming vs Subaru
I have a friend, long time RV-4 driver, long time ex-military fighter pilot, who had a Subaru on the front end. After his 9th off field landing due to Subaru failure he finally exchanged the Subaru with a Lycoming. Still flying the RV-4 with Lycoming several years later until he bought an RV-8, yes with a Lycoming.
Stu McCurdy (Falcon)
RV-8, 78TX, Flying
Formation Flying, Inc (FFI)
Falcon Flight
10-12-2017, 03:02 PM
been here awhile
Originally Posted by Snowflake
Good idea.
Profile states RV-7.
Very glad to see plane and pilot survived.
10-12-2017, 04:39 PM
447BB is an RV-7 (tail dragger)
The engine failure occurred without warning at about 500 feet on climb out on the first flight. Fortunately almost straight ahead was a fairly flat and smooth pasture.
Evidence of internal failure includes fact that the crankshaft will not rotate, engine coolant in the oil pan, very dirty oil and some metal chunks removed from the muffler. Some chunks are ferrous and some apparently aluminum. Pretty sure one metal piece is a piece of a piston ring.
We have not removed the oil pan for further investigation. At this point, the engine is a very big paperweight in the back of the hangar.
10-12-2017, 06:29 PM
447BB I have a recently overhauled Lycoming IO-360-C1C6. This is a 200hp angle valve 4 cylinder that can take a propeller governor
10-12-2017, 09:00 PM
I made the switch from a successful flying 6cyl Subaru to an IO-360-B1E and Hartzell prop. If you are interested, the fuel system installed in your aircraft gives you an excellent start on some sort of electronic fuel injection on a lycoming.
I'd be happy to discuss my experiences with you,
Caleb Lesher
Flying RV-7A N542LC with SDS Electronic fuel injection.
RV-8 Kit for sale
ATP CFI A&P
Air Ambulance driver
Based at EKA, Northern CA
