Old 10-08-2017, 03:43 PM
Ffrankos's Avatar
Ffrankos Ffrankos is offline
Default Anybody tried one of these?
I am in a hanger that is unheated and am thinking of buying this. My thought is that I can use my cell phone to turn on my engine pre-heater. For those who have one of these, do I just need to get a SIM card, and plug it in?
thanks!!
https://www.tomtop.com/p-c2036uk.html?currency=USD&Warehouse=CN&%7Bifdbm:ai d=dc2dynamic&mid=10000008003&utm_source=SEM&utm_me dium=DoubleClick&utm_campaign=$%7BINSERTION_ORDER_ ID%7D&utm_adgroup=$%7BCAMPAIGN_ID%7D%7D&aid=gplaus yly&gclid=CjwKCAjwmefOBRBJEiwAf7DstIJP9qimy5_6ZP5v wrVcKtZrjbUw2MYo71cpjUmzKQC5qLRI7pLrkRoCRJEQAvD_Bw E
Frank
RV-6a KEIK
Old 10-08-2017, 04:54 PM
Use the search function to find a switch that you're sure will. I don't know anything about the one that you linked, but I have two Chinese cheapies on my shelf (from different manufacturers) that don't work. One had incomprehensible directions, the other... well, I don't remember.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-08-2017, 06:12 PM
gfb gfb is offline
I have a $20 from Amazon that works great. The $100+ ones you see are basically exactly the same circuit board with a different box and directions in English. If you can figure out the engrish on the cheap ones it will work great.
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 10-08-2017, 06:20 PM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
I use 2 light bulbs inside of an aluminum dryer vent and shove one end in the bottom of the cowl and let the other end lay on the floor. when it gets cold I have to wrap the vent with rags to insulate it and I also cover the cowl with blankets. It maintains about 50 degrees on cold days. I have NO hanger insulation or heat but it is still warmer than outside.
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
Old 10-08-2017, 07:58 PM
wirejock's Avatar
wirejock wirejock is offline
Default Light bulbs
What wattage?
Pretty efficient if it maintains 50 in Minnesota.
To the OP, there was an article in Sport Aviation about building a home brew device like the one in your link.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 10-09-2017, 08:53 AM
Ffrankos's Avatar
I did a search and found a lot of good information but nothing specific about this switch.
Frank
RV-6a KEIK
Old 10-09-2017, 08:55 AM
Ffrankos's Avatar
do you have the part number? $20 is a great price. Did you buy a SIM card. It looks like I can get a free one from Freedom POP.
Frank
RV-6a KEIK
Old 10-09-2017, 11:00 AM
gfb gfb is offline
This is the one I got, it was cheaper a couple years ago. Just search for outlet cell switch and there are a few options.
https://www.amazon.com/Docooler-Wire...ket+switch+sms
Old 10-09-2017, 11:38 AM
jonweisw jonweisw is offline
I just built the one in Sport Aviation (the EAA mag) that appeared a few months ago. Easy to build, cheap, and works very well as a switch. You text it and it turns on and confirms for you that its on, etc. Only works with phone numbers that you provide it with (ie, nobody can spam it).
Old 10-09-2017, 01:46 PM
bobnoffs bobnoffs is offline
i have one and it works great.......with some mods. my board wouldn't function in the cold so i ended up putting it in a styrofoam box and using a 5 watt bulb on a line thermostat to keep it above 40 deg.,switch may not be up to the load you will use. my cell switch switches a contactor that completes the circuit to the heater.
but is nice to dial up a few hours before you go up and i think it is important that i am minimizing my fire risk by the small amount of time the heat is on.
350 watts of auto heater stuck on several places on the block of my jab 3300 will warm everything in 3 hrs for an oat of say 15-20 deg. i don't remember the number but there is a max temp of the block where the block gives off as much heat as it is absorbing. so it is not like you are firing up the doomsday device.
i suppose 3 times as much wattage would cut down heat up time but also get you closer to the doomsday device!
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
