Old 09-27-2017, 06:18 AM
Tom Martin Tom Martin is offline
Default Canopy release
I know that this has likely been discussed before but the RV14 is a bit different then the other RVs in regard to the canopy release. It would be nice to have a discussion about what will happen if you feel the need to pull that emergency canopy release.
Should this be done only at very low airspeeds, just before touch down?
Do you release the main canopy latch first?
Assuming that the unlatched canopy rises a few inches, as has been demonstrated with other models, when you pull the emergency release what are the chances that this thing will come back and hit the occupants.
What if you release the forward pins before the aft latch? Would the canopy then lift up and flip back without hitting occupants?
Under what circumstances would you pull the release and why?
Smoke or fire in cockpit?
Water landing?
Having a release handle in an aircraft comes with some responsibilities. One would really regret making your outcome worse by pulling the handle!!
I worry about some kid or child like adult just pulling the handle because it looks like something that should be pulled. To that end I have added some brass safety wire from the handle to the panel. I have tested it and it takes a sharp pull to break the wire but it might stop a random curiosity or accidental pull of the release.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 09-27-2017, 06:25 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Pin
I drilled a hole in the release handle on the backside of the panel. I place a clip in the hole while the canopy is open. The clip is for when I have passengers for non-aerobatic flight. I only remove the clip for aerobatics.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
Old 09-27-2017, 08:33 AM
n982sx n982sx is offline
I have done a similar thing as Marvin. Since I haven't done and don't plan on doing aerobatics in the 14 anytime soon, I have the handle placarded as 'Canopy release handle, maintenance use only'.
If I do decide to do aerobatics, the bolt is removable, and I could substitute a release pin to be used for non aerobatic flight. I did not like the idea of the canopy being able to be released without parachutes being worn. It's my belief that if the canopy is released it may very well take out the VS and Rudder or the entire tail.
My opinion is if the handle is pulled you must plan on jumping from the aircraft, so the handle should not be able to be pulled unless you are wearing parachutes. Installing or releasing the pin would be a simple process that could be a checklist item.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 09-27-2017, 11:50 AM
bkervaski's Avatar
bkervaski bkervaski is offline
For the guys that are not having the canopy release handle protrude through the panel, what are you doing?
I also have a fear of placing it on the panel and that kids may grab it.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-27-2017, 12:45 PM
rvbuilder2002's Avatar
That is the design intent of the release handle.
Because the airplane is approved for aerobatics, it is to proved a means of exiting the airplane to use the chute that is required for each passenger (unless solo).
I personally would never pull the jettison handle in flight for any other purpose.
Scott McDaniels
Hubbard, Oregon
Old 09-27-2017, 01:46 PM
Ron B. Ron B. is offline
One might use this in the tragic event of ditching, once stopped. I removed my canopy once after installed and you have to pull quite hard and far out so it would have to be deliberate.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 09-27-2017, 02:04 PM
Very possible. That is why I said I wouldn't use it in flight (unless planning to exit with a chute).
Scott McDaniels
Hubbard, Oregon
Old 09-27-2017, 03:53 PM
Bavafa Bavafa is offline
A very good question, one that I have been thinking about. In my 7, I did not extend the handle beyond the subpanel for the very same reason. I wonder if there is a safety mechanism in place that it can not be pulled accidentally (other than the pin in the back) which makes it impossibly to pull if in place and canopy closed.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-27-2017, 04:11 PM
If it's a real concern to you, then add something like you see on fire extinguishers, etc. a 2ndary safety pin on the cabin side of the panel, so a 2 step process is required to jettison. Pull the safety, then pull the handle. At least it would improve the odds of noticing a passenger's actions before disaster strikes.
Old 09-27-2017, 04:16 PM
bkervaski's Avatar
I see a number of finished RV-14's out there with no canopy release handle .. is there any among you who have done that and if so what were your thoughts and how did you handle the release mechanism?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
