Old 09-25-2017, 05:16 PM
Gizmos Gizmos is offline
Default Which facet backup fuel pump
I am looking for which back up facet pump for a o-320 carb engine? How much psi, range?
Old 09-25-2017, 06:12 PM
guccidude1 guccidude1 is offline
I used the low pressure Facet pump, 3-5 psi IIRC, for my carb. Dan from Reno
Old 09-25-2017, 06:45 PM
Sam Buchanan's Avatar
been here awhile
In the Vans store:
http://www.vansaircraft.com/cgi-bin/...duct=pump-carb
Sam Buchanan
RV-6
Fokker D.VII replica
Old 09-25-2017, 08:35 PM
Default Backup pump
Thanks, I was given a new pump but was not sure what everyone else was using. Just finishing running my fuel lines inside of fuse..
Old 09-26-2017, 05:14 AM
snopercod's Avatar
I'm using a Facet Gold-Flow 40007 between my gascolator and mechanical fuel pump. It's rated at 36 GPH at 4.0-5.5 PSI, and has a 74u filter inside under that twist-off cap. It's "free flow" with no internal check valve. Self-priming to 24 inches vertical fuel lift. I mounted mine vertically, as recommended.
(2020 dues paid)
