Old 09-24-2017, 09:05 PM
boom3's Avatar
boom3 boom3 is offline
Default Prop governor blank cover
I've struggled over the years with oil leaks with this cover. I'm guessing the stud and nut size were engineered to mount the governor not just a cover. So my question is what should I torque the nuts at? I'm guessing I'm either under torquing or over torquing it.
It must be me because I've tried a new cover and numerous gaskets.
Thanks!
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 09-24-2017, 09:36 PM
Larco's Avatar
Larco Larco is offline
Maybe clean everything off real well and put the cover in place by hand to check for a rock of the cover against the adapter or the length of the studs, maybe to long and the nut bottoming out on the stud when torquing? Some times it is the adapter to engine gasket leaking for the same reason and blows back onto the the gov or plate? Just a thought.
Larry
Old 09-25-2017, 07:58 AM
BobRv4 BobRv4 is offline
Default Studs
Ive been there, was oil leaking out of the studs/nuts/holes in cover.
I think one or more studs goes thru the block, try removing them, goop up with sealant or gasket maker, then seal the treads/holes.
I also sanded the cover flat on a piece of glass, lapped it flat, that helped also.
Old 09-25-2017, 08:31 AM
boom3's Avatar
Great advice Bob! This could very well be my issue.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 09-25-2017, 08:47 AM
boom3's Avatar
Thanks Larry. The adapter to engine gasket looks pretty good and I'm thinking it's just the cover. (I only say that because the leak has gone away for awhile in times past and I've only ever messed with the cover.) I may get rid of the adapter all together and just put a blank directly on the engine. (My engine came all set up for a constant speed but I went fixed pitch. So I have the adapter and the hardline that runs to the front of the engine, none of which is necessary now.)
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 09-25-2017, 09:38 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Apparently I had the same problem. When the local engine shop test ran my engine the notes so they had to stop mid-test and fix a leak on the plate due to it being warped.
Cost me a little extra $$ since I had assembled the accessory case area.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-25-2017, 01:39 PM
Larco's Avatar
If you do eliminate the adapter remember to remove the prop and punch a hole in the rear crank plug?
Larry
