I have an EarthX ETX680 battery, G3X GDU460's, and VP-X Pro. The battery fault warning output wire is connected to the Garmin GEA24 as a discrete input, configured as "Active Low." It works - I had a blinking CAS alert a couple of months ago, which apparently indicates an internal cell imbalance. EarthX replaced the battery under warranty, and commended me for actually hooking it up, which apparently a step that some builders / installers omit. Download the manual from EarthX - there is a diagram and instructions for Garmin and some other EFIS vendors.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
