09-08-2017, 09:05 AM
New Wording for Passenger Warning
Just a "heads-up", as of September 21st, 2017, new ruling on the Passenger Warning;
Except for single place aircraft, the following placard must be displayed in the aircraft in full view of all occupants: “PASSENGER WARNING—THIS AIRCRAFT DOES NOT COMPLY WITH FEDERAL SAFETY REGULATIONS FOR STANDARD AIRCRAFT.”
Note that Experimental, Light-Sport, or Amateur-Built is no longer required wording. This makes for a more "standardized" placard.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
09-08-2017, 09:08 AM
I hope this is an April Fools joke a few months early.
Tim
09-08-2017, 09:09 AM
Tim
Nope, it's in the new FAA Order 8130.2J.
09-08-2017, 09:12 AM
Is this only for newly certificated E-AB's, or is it retroactive? If retroactive, are new ops lims required?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
09-08-2017, 09:13 AM
It is NOT retroactive. Everything you have now is still good.
09-08-2017, 09:21 AM
Tim
Why? All they did was drop the " IS AMATEUR-BUILT" from the current placard. I do hate it though as to me it implies that my aircraft is some how sub-standard.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
09-08-2017, 09:26 AM
So is my passenger warning on the panel of my yet to be inspected airplane going to cause an issue with the inspector? I used the old wording.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
09-08-2017, 09:28 AM
Not necessarily so.
Better wording would be:
"This aircraft is not required to conform to...."
I don't remember seeing a notice and comment opportunity on this, if it was deemed a regulatory change.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworked: N4032Q RV8A (8/2017)
Building: S-21 Outback/Titan, tail and cockpit mated (3/2020)
KELY/Ely, NV
09-08-2017, 10:11 AM
The "Why" is to somewhat standardize the placard so that a different placard is not required for different category of aircraft. i.e. the same placard works for experimental amateur-built and experimental light-sport aircraft.
09-08-2017, 10:14 AM
Mel I wasn't asking you why - I asking Tim why.
PP ASEL-IA
WAR EAGLE!
