Old 08-25-2017, 04:12 PM
JDA_BTR JDA_BTR is offline
Default Rollbar Tap Fluid
About to drill #36 and tap 6-32 the rear window holes into the rollbar. What tap fluid is safe or recommended for this process?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 08-25-2017, 05:03 PM
Nova RV Nova RV is offline
I used Boelube and went very slowly with the tap (by hand of course). I would only cut a turn or two then back it out and clean out the cuttings, add more lube and cut a couple more turns.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 08-25-2017, 05:10 PM
ok good, I didn't know that was plastic-safe.
Old 08-25-2017, 05:56 PM
Ron B. Ron B. is offline
Make sure you use the revised plans for securing the small attach screws ( no thread locker as in revision 0).
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
