  #21
Old 08-22-2017, 05:12 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I'd add that the Gen 2 is designed with aviation 100% in mind rather than a spin-off adapted from automotive as the original CPI was. It will have some of the new features recently introduced on the EM-5 as well.
The advantage of several product lines- once we write new software for one, that code can be carried over to other products at little additional cost outside validating it.
In case some new people are following this thread and are unfamiliar with what the CPI offers, here's a quick rundown:
Timing adjustable in logical 1 degree increments at 500, 750, 1000 rpm and then every 100 rpm above that
Timing adjustable with MAP- retard or advance which is subtracted/ added to the basic rpm programmed timing. 1 degree increments
Adjustable coil charge time
Adjustable cranking retard
LOP switch adds a programmable amount of advance to the base RPM/ MAP curves
Adjustable rev limiter
Integral coil test function without engine running plus error LED for quick diagnostics
12V tach signal output
Runup mode for testing coil packs (single module driving both plug sets)
Integral MAP sensor
Hall triggered off the flywheel, Conformal coated PCBs, no blast tubes required, no maintenance required outside of annual spark plug checks.
Easy to understand programming
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 08-22-2017, 05:39 PM
Av8rRob's Avatar
Av8rRob Av8rRob is online now
Dumb questions from newbie, does the sds system require a mixture knob? Does it require fuel return lines? What type of cockpit switches/controls are needed? What is the recommended electical system for this setup (I assume dual batteries)?
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 08-22-2017, 05:58 PM
William William is offline
Hi Ross I have a dual cpi setup on my RV6A and it has performed flawlessly. I'm not familiar with the adjustable coil charge time? I don't recall seeing that in my setup?
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 08-22-2017, 06:10 PM
plehrke's Avatar
plehrke plehrke is offline
Bill
About the 5th one under the hidden settings.
These can be accessed by holding down the left arrow button when powering up the CPi unit.
From manual page 12:
Adjusts the charge time or dwell of the coils in milliseconds. Default is 3.5mS. Increasing may help spark if running high boost on turbo/supercharged engines. Increasing dwell will increase current draw of the coil pack, and could cause the coil pack/ignition fuse to blow at high rpm. If experimenting with larger coiltime settings, rev the engine in neutral and monitor ignition current. One way to monitor current is to pull the coil pack fuse out and substitute your ammeter leads into the fuse socket. Fuse should be at least 30% greater amperage capacity than what you observe on the meter at redline.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 08-22-2017, 06:42 PM
tim2542 tim2542 is offline
"We also disable the LOP switch input above about 25 inches as further protection in case you forget the switch position."
Ross is this new? I purchased a system in January, is that included in my system?
Thanks, Tim Andres
Old 08-22-2017, 09:48 PM
rv6ejguy's Avatar
This thread is really about P Mag and the SDS CPI. The SDS EFI is a different product doing fuel and spark. I'll PM you answers to your questions here.
Old 08-22-2017, 09:50 PM
rv6ejguy's Avatar
Bill
This feature is in the setup mode as it's not something most folks need to play with. It allows max coil saturation when using different coil types.
Old 08-22-2017, 09:51 PM
rv6ejguy's Avatar
Thanks, Tim Andres
That feature has been in there for some time. What version of software do you have? (displays on bootup)
Old 08-23-2017, 07:45 AM
j-red j-red is offline
I don't mind the green (doesn't look nearly as terrible as the GRT engine monitor!) If I knew during the build what I know now, however, I probably would have hidden both of them somewhere out of sight and left that panel space for something else (DVD player for passengers??? )
Been running 1 impulse coupled slick and the SDS for about 6 months now without a hiccup.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 08-23-2017, 07:52 AM
rv6ejguy's Avatar
Should we keep the green then?
